BLO before wipe on poly?
Forum topic by Mark posted 05-18-2011 11:18 PM 1980 views 0 times favorited 15 replies Add to Favorites Watch
View Mark's profile
Mark
1807 posts in 3176 days
05-18-2011 11:18 PM
Okay, I’m just a simple man when it comes to finishing and I know alot of you ppls have crazy combos when it comes to finishing. Now is there a purpose to putting on BLO before poly?
-- M.K.
15 replies so far
View degoose's profile
degoose
7227 posts in 3257 days
#1 posted 05-18-2011 11:24 PM
I don’t use it but a mate of mine swears it makes the grain pop by using BLO first…
View Mark's profile
Mark
#2 posted 05-18-2011 11:27 PM
okay thx larry thats what i was suspecting…..does water just do the trick instead of blo?
-- M.K.
View peteg's profile
peteg
4227 posts in 2725 days
#3 posted 05-18-2011 11:47 PM
I always like to seal the grain with shellac or thinned poly first, you can then finish sanding with a thin oil which will help “pop” the grain, then finish with poly or oil or whatever you want
must admit I am not a fan of BLO, takes too long to dry and usually gives a blotchy colour acrss any end grain IMHO
35099 posts in 4303 days
#4 posted 05-19-2011 12:12 AM
make the grain pop, you can also use dewaxed shellac for the same purpose. Don’t use waxed shellac or the poly won’t stick.
View Dan'um Style's profile
Dan'um Style
14171 posts in 3885 days
#5 posted 05-19-2011 12:29 AM
Karson is right… blo then shellac, it will look nice.
View Gary's profile (online now)
Gary
9290 posts in 3335 days
#6 posted 05-19-2011 12:34 AM
Mark….you’re not serious about that water question, are you????
View crank49's profile
crank49
4029 posts in 2873 days
#7 posted 05-19-2011 12:43 AM
I love BLO. Mainly cause they won’t allow anyone to sell it in California. If they think it’s so bad, it must be pretty good stuff.
View richgreer's profile
richgreer
4541 posts in 2977 days
#8 posted 05-19-2011 12:46 AM
Everyone has their own opinion on finishes. I like a coat of WaterLox, which is basically a tung oil, before applying multiple coats of MinWax wipe-on poly.
View Nate_in_Denver's profile
Nate_in_Denver
5 posts in 2467 days
#9 posted 05-19-2011 12:51 AM
BLO will pop the grain before the Poly topcoat
13594 posts in 3243 days
#10 posted 05-19-2011 02:12 AM
mark
the water is just for a quick look
but will raise the grain
so must be sanded lightly
proir to any finish
View interpim's profile
interpim
1170 posts in 3361 days
#11 posted 05-19-2011 02:20 AM
I’ve purchased BLO in California before… found it at ACE hardware
-- San Diego, CA
View Steven H's profile
Steven H
1117 posts in 2962 days
#12 posted 05-19-2011 02:29 AM
BLO or tung oil finish will pop the grain look.
What you can do is add BLO or tung oil with any your favorite poly(varnish) and thinned with paint thinner, naphtha.
It will become a oil/varnish blend. You dont need to buy Watco danish oi, make it your own at cheaper price.
l
View Mark's profile
Mark
#13 posted 05-19-2011 03:21 AM
thx alot everyone….sooo many combinations. I’m just curious right now because I want to start testing different combinations to find out which I like best because I’m really getting bored of wipe on poly :/ ...I know nothing when it comes to finishing and I really want to practice on it because its my weakness.
-- M.K.
View JJohnston's profile
JJohnston
1622 posts in 3193 days
#14 posted 05-19-2011 03:31 AM
Rich Greer, Waterlox is varnish, just made with a different type of resin than poly. It would do just as good on its own as (possibly better than) layering different varnish types.
-- "A man may conduct himself well in both adversity and good fortune, but if you want to test his character, give him power." - Abraham Lincoln
View gfadvm's profile
gfadvm
14940 posts in 2592 days
#15 posted 05-19-2011 04:39 AM
I use Spar/mineral spirits in a 2/1 mix and get the same look as blo with a much shorter dry time.
