Long Edge Sander for Cheepskates
« back to Coffee Lounge forum
Forum topic by poopiekat posted 107 days ago 166 views 0 times favorited 7 replies Add to Favorites
View poopiekat's profile
poopiekat
56 posts in 123 days
107 days ago
Having worked in several shops with great equipment, I’ve often yearned for access to those same tools in my basement workshop. Since it’s just a hobby, it’s impossible to justify the cash outlay, you could just never get your moneys’ worth even if you bought ‘em all. With necessity being the Mother of Invention, here’s what I did about not owning a good edge-sander:
I found a perfectly good used industrial belt conveyor, which was about 8 inches wide and about 4 feet long.
Researching the available belt sizes for Delta and Grizzley edge sanders, the 6” X 89” belts looked like a possible fit, and were indeed a popular size. No use building my own edge sander to an obsolete belt size! With the conveyor shortened to approximately a 43” wheelbase, the belt fit just about right. The rollers were approximately 3.5” in diameter. The belt fit right on, and the driven roller had micro-metic adjustments for belt tension. I built a quick bench for it, and mounted a 1/3 horse washing machine motor to it. I’ll get an enclosed moter for it, for safety.
One word about building your own: To make the belt track correctly, at least one roller must have a ‘crown’ in the middle. Of course the two axle shafts should be perfectly parallel as much as possible, but the crown will make the belt seek equilibrium in the center of the roller. You don’t want a silicon carbide belt straying off-center and slicing the machine up to bits!!
I have been using it in a horizontal position but my next task is to mount it upright on its side like the commercial units. I’m not handling large panels much these days and get great results with it lying flat on its back as in the photos. Remember the belt runs left-to-right as you face it. I plugged it in and it has not needed ajustment at all except when changing grits, one belt a bit longer than another. I make lots of small dovetailed boxes; this unit squares the corners perfectly, and performs otherwise about as well as a real one!!
-- If stradivarius was alive today, he'd be using Gorilla Glue.
poopiekat
107 days ago
http://i280.photobucket.com/albums/kk161/poopiekat/edgesander1002.jpg
http://i280.photobucket.com/albums/kk161/poopiekat/edgesander1001.jpg
Sorry, I didn’t post the links for the pictures.
Any questions? I’d be glad to help!!
Save that $1500 you’d have to pay for a commercial unit. Mine cost about $50 in materials.
View bryano's profile
bryano
526 posts in 322 days
107 days ago
Nicely done job on much needed equipment
-- bryano
poopiekat
107 days ago
Thanks, bryano!
I forgot to mention, the sanding surface area was backed up with .050” stainless sheet metal; ithe belt MUST have a flat platen surface behind it, but any low-friction surface will probably work okay… real ones often have a graphite pad but mine works great, and a bigger motor, say 3/4 HP and it probably won’t slow down for anything.
I once built a stroke sander out of “Unistrut” steel, and wooden drums, complete with oscillating table. I could sand an entire door with it, with the 8”X 186” belt” Wish I had pictures…It’s still in use in a shop somewhere, 15 years after I sold it
bryano
107 days ago
Im very familiar with unistrut. Its very handy. Someone on this site (sorry, I forget who) made some nice clamps out of some unistrut and threaded rod. I have plans to build some my sely in the near future.
-- bryano
View GaryK's profile (online now)
GaryK
8182 posts in 377 days
105 days ago
Looks knid of like an upside down stroke sander.
View rikkor's profile
rikkor
6465 posts in 263 days
105 days ago
Nice construction of a useful tool.
-- Maplewood, MN
poopiekat
104 days ago
Yes, GaryK, a stroke sander is kinda based on the same thing as my edge-sander concept…and yes, mine is laid on its back, rather than the end rollers in a vertical position, but that upgrade is next. I did indeed build a stroke sander once as mentioned above…
I’m hoping that there are other people out there who have built their own shop equipment out of scraps and salvage….and saved hundreds of dollars in the process. Please post what you’ve done!! I’m sure there’s lots of interest in home-made tools.
Bookmark And Share This Page
