Materials Cut Sheet List
Forum topic by Kevin posted 05-18-2011 04:22 AM 2831 views 1 time favorited 11 replies Add to Favorites Watch
View Kevin's profile
Kevin
462 posts in 3198 days
05-18-2011 04:22 AM
Topic tags/keywords: wall floor cabinet sketch materials plan
Hi,
Does anyone have a pic or something that shows a material cut list sheet for some standard cabinets for the floor and wall? I can probably do it manually, but I thought maybe a fellow LJ might have one already handy. I’ll be building some wall/floor cabinets (face frame) for my garage soon.
Thanks,
Kevin
-- Williamsburg, KY
11 replies so far
View Lee Barker's profile
Lee Barker
2170 posts in 2843 days
#1 posted 05-18-2011 05:35 AM
There are enoughl stylistic differences from one cabinetmaker’s box to another’s that I fear a cut list alone would not save you time in the long run.
For instance: Some build a separate toekick; others make it integral. Some bottom rails are 1 1/4 wide to accommodate a half inch overlap of a 4” toe kick. Some hang top and bottom rails through the full run, others butt them at a mid-run stile. Then you get into drawer sizes and layouts. Yeah.
Better to make your own drawing of a box, make those stylistic decisions, and build to your stile. Pun intended.
If you want to ask about basic dimensions and how I do the faceframes, I’d be glad to do that by PM.
Kindly,
Kevin
#2 posted 05-18-2011 01:12 PM
You make a good point there Lee. Didn’t think about that really when I posted. I’ll take a look at some different ones and see what I come up with :)
Thanks again Lee,
Kevin
-- Williamsburg, KY
View DLCW's profile
DLCW
530 posts in 2647 days
#3 posted 05-18-2011 06:19 PM
Kevin,
If I can figure out how to put pictures into a response to your post I can upload several pictures of a base and upper cabinet.
Can anyone tell me how to put pictures in a response? I know how to put pictures in an original post, just not a response.
Thank you.
-- Don, Diamond Lake Custom Woodworks - http://www.dlwoodworks.com - "If you make something idiot proof, all they do is make a better idiot"
View HerbC's profile
HerbC
1754 posts in 2852 days
#4 posted 05-18-2011 06:24 PM
Don (DLCW),
You should be able to click the img button and browse to find the picture on your computer and then upload it (by clicking on the Insert this image button). Works for me, only problem is it initially inserts the code which begins !https… at the beginning of the post and then you have to cut and paste it where you really want it…
Bottom line, work for me, keep trying it should work for you too!
Be Careful!
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
View DLCW's profile
DLCW
#5 posted 05-18-2011 06:45 PM
Thanks Herb!
Here are pictures of the cabinets and sample cut and parts lists I used for a standard upper and base cabinet.
Lee Barker
#6 posted 05-18-2011 08:06 PM
LJ at its best. Nuff sed!
Kevin
#7 posted 05-19-2011 02:34 AM
LOL Herb, didn’t know what you were meaning there for a minute :)
DLCW, actually that’s what I was looking for. Just needing something like this for the cabinets in the garage. Props to DLCW for posting, I agree with Lee!!!
Much appreciated,
Kevin
-- Williamsburg, KY
View DLCW's profile
DLCW
#8 posted 05-23-2011 03:57 AM
Kevin,
I use a program called eCabinets from Thermwood Corporation. The program is free and very powerful. It can do a lot of really neat things. It does have a learning curve and because it is totally parameter driving, there is no drag and drop anything. Everything I posted for you here is a result of screen shots from the eCabinets software.
Kevin
#9 posted 05-23-2011 05:47 AM
Thanks Don. I will have to check that out and play around with it some.
Kevin
-- Williamsburg, KY
View Jahness's profile
Jahness
70 posts in 2757 days
#10 posted 05-23-2011 06:24 AM
Kevin, have you looked at Cutlist Plus? It’s very easy to use and has alot of features that can be tweeked to your liking.
-- John
Kevin
#11 posted 05-26-2011 03:18 AM
Just took a look at cutlist plus also. That has pretty nifty features also.
-- Williamsburg, KY
