Free plans, "SWEET"tablesaw crosscut sled from The Wood Smith Shop
Forum topic by bubinga posted 05-18-2011 03:09 AM 33931 views 22 times favorited 6 replies Add to Favorites Watch
View bubinga's profile
bubinga
861 posts in 2631 days
05-18-2011 03:09 AM
Topic tags/keywords: resource jig tip tablesaw crosscut sled
There is also a nice Adjustable Tenon Jig
These are set of really nice plans, for a sweet tablesaw crosscut sled. OPTIONAL BOX JOINT JIG attachment, you can widen the kerf for dadoing. You may have to sign up for the free E-news letter to get access to the downloadable plan.
This is a plan is worth buying, if it wasn’t free
Some good stuff at,The Wood Smith Shop
http://www.woodsmithshop.com/episodes/season4/403/
Here is another idea
-- E J ------- Always Keep a Firm Grip on Your Tool
View devann's profile
devann
2246 posts in 2656 days
#1 posted 05-18-2011 03:15 AM
Thank you EJ, I’ll check this out.
10249 posts in 3611 days
#2 posted 05-18-2011 04:33 AM
I like the hyperbole in the instructions describing the jig as “rock solid” (which,
being made of wood, it of course isn’t).
Good design though. Solves a relevant problem. Adding a replaceable throat
plate to the right (the “good” side presumably) would compensate for blades
chewing up the edge of the jig over time and widening the kerf and resulting
in more chipping of the workpiece.
bubinga
#3 posted 05-18-2011 04:56 AM
You could easily rabbit the edges and put in, and a replaceable insert, and use a sink cut out, or phenolic faced plywood to start with, I don’t mess with wood runners, I use 3/8×3/4 steel bar stock, one eight-foot piece goes a long way, and if the jig goes bad you just make a new jig and use the same runner
bubinga
#4 posted 05-19-2011 08:10 AM
Added another idea
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3676 days
#5 posted 06-08-2011 06:34 AM
Thank you for posting this link.
I’ll second what CPB said above where a in person class can offer considerably more than reading, watching or even listening about a process, fixture, technique or whatever. Don’t get me wrong I don’t think in person is the only way to learn, but it is a real good way to learn for most people.
I’ll have to check out more of the projects on that site, I may even need to start buying copies of the magazine, it looks like a really good resource. I wonder if anybody sells it here in Brandon?
View lanwater's profile
lanwater
3111 posts in 2897 days
#6 posted 06-08-2011 07:19 AM
Ok! I will be building more sleds.
Thanks!
-- Abbas, Castro Valley, CA
