| Forum topic by bringitonhome | posted 734 days ago | 1377 views | 0 times favorited | 7 replies | ![]() |
734 days ago |
Hi- Also – any advice on how much room to give the panel to expand in the groove? Thanks! |
7 replies so far
#1 posted 734 days ago |
Mdf is the best substrate for veneer but ply will do fine for door panels. You will not need to plane it down as it isn’t actually 1/4” thick. With the veneer it will most likely fit nice and snug in a 1/4” groove. Use the smoothest ply you can find as any irregularities may telegraph through to the surface. I prefer to leave 1/8” of play in the groove along with a 1/4” spaceballs. -- http://www.niceashplanes.com/ http://www.efcabineture.com/ |
#2 posted 734 days ago |
If you have a real lumberyard nearby that sells to cabinetmakers, you will probably be able to find 1/4” MDF core ply in many species. -- Adversity doesn't build character...................it reveals it. |
#3 posted 734 days ago |
MDF or baltic birch for the substrate. Don’t cut the dado’s in the rails and stiles until your panels are complete. This way, you can size the dado to fit the panel perfectly. Also make you panel about 1/4” narrower and shorter then your dados in the rails and stiles. Like rhett says, you will want to put space balls in the dados to keep the panels from rattling around in the door frame (very annoying). YOu will want to make sure that you glue veneer to each side of the substrate to stabilize it. As far as glueups go, you can either use a vacuum bag to clamp the panel between the two pieces of veneer or you can build some 1 3/8” thick clamping boards from 3/4” laminated MDF. You will want to put 2 or 3 coats of paste wax on the side of the clamping boards that will touch the veneer so you don’t accidentally glue the veneered panel to the clamping boards. Another option is to put wax paper between the clamping boards and the veneer. I use plastic resin glue (DAP Wood Weld) because of its long open working time. You can also use white glue as it dries clear. I don’t use yellow glue because if there is any glue squeeze through the veneer (happens all the time) it will look really bad. White glue will be clear. I would highly suggest practicing on some scrap before you work with expensive veneer. MDF is cheap and any mistakes can be learned from before you tackle the real thing. -- Don, Diamond Lake Custom Woodworks - http://www.dlwoodworks.com - "If you make something idiot proof, all they do is make a better idiot" |
#4 posted 733 days ago |
Many thanks all for the help. I guess because the veneer will expand/contract at a different rate than ply is the reason you have to veneer both sides? Kind of a drag – twice the product for a side of the panel that will only be seen when the door is open. I was originally planning on veneering only the outside. FYI – I’m planning on using a veneer product that is an ultra-thin (1/42”) ‘slice’ of hardwood, not the type that is paper-backed and comes rolled-up, if that makes any difference in technique… |
#5 posted 733 days ago |
You will need to veneer both sides. Otherwise the panel will change shape and cause you problems. The way to do it is to put your nice veneer on the outside3 face and a less costly veneer (soft maple or something like that) on the inside. This way you achieve the goal of stabilization at a reduced price. You other option is to do what I did for some of my shop cabinets. I found some 1/2” plywood at the local big box store that had some incredible curly maple patterns to it. Out of 20 sheets I had 6 sheets that are absolutely amazing. I applied Arm-R-Seal finish and the grain really popped out. Also in the Cherry credenza and A/V cabinet I posted here I found some highly figured 1/4” cherry plywood that I used for panels. Theses sheets of plywood had incredible rope pattern figure. When finished the figure and color really popped out. -- Don, Diamond Lake Custom Woodworks - http://www.dlwoodworks.com - "If you make something idiot proof, all they do is make a better idiot" |
#6 posted 733 days ago |
I don’t bother to veneer both sides of a panel if it will be captured inside a door frame. Between the rail and stile holding the panel flat and how thin veneer is, I don’t see how it could distort enough to be of concern. I have never had an issue or a callback. I should make note that on wide doors I always add a center mullion and do veneer both sides of flat panel doors or any piece that is not contained within a frame. -- http://www.niceashplanes.com/ http://www.efcabineture.com/ |
#7 posted 733 days ago |
You are right. For MDF it would be overkill to veneer both sides if going in to a frame. You just have to be willing to see the MDF on the inside of the door. Personally, if I you use a plywood substrate (baltic birch or appleply) I would veneer both sides. But that’s just me. :-) -- Don, Diamond Lake Custom Woodworks - http://www.dlwoodworks.com - "If you make something idiot proof, all they do is make a better idiot" |
| Forum | Topics |
Woodworking Skill Share
8790 |
Woodturning
220 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
78 |
Finishing
1530 |
3547 |
15767 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2837 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6156 |
