Forum topic by bubinga | posted 05-17-2011 08:26 AM | 7083 views | 0 times favorited | 15 replies | ![]() |
Topic tags/keywords: question jig dovetail jig router joining Thinking of buying one . -- E J ------- Always Keep a Firm Grip on Your Tool |
15 replies so far
#1 posted 05-17-2011 02:33 PM |
i have it, it works pretty good and is easy to set up. i cut a pretty nice half tail on my second practice cut once i figured out how to set up the wood, i didnt read the instructions right otherwise it would have been perfect on my first try only thing i had problem with is i overtightened the little clamps and warped the alluminum. i had to mess with it for awhile to get it straightened out. i put some sticky sandpaper on the jig to hold the wood so i wouldnt have to tighten it as much and all is good. i like that you can use it on the router table or with a hand held router either way works |
#2 posted 05-17-2011 10:47 PM |
Gotta be more than one of these jigs out there -- E J ------- Always Keep a Firm Grip on Your Tool |
#3 posted 05-17-2011 11:35 PM |
Never heard of it… -- Randy "You are judged as much by the questions you ask as the answers you give..." |
#4 posted 05-17-2011 11:41 PM |
I had one and works great out of the box for the first 2 uses then the bearing starts to just disinegrate, the jig becomes sloppy and just not a pretty sight. I suggest the porter cable 12” or 24” i have met some people with these jigs and they couldnt be happier. |
#5 posted 05-18-2011 03:00 AM |
What bearings ? I just see a cast aluminum piece and some threaded footed clamps. You must be mistaken. Here it is: http://www.rockler.com/product.cfm?page=30221 -- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia |
#6 posted 05-18-2011 03:13 AM |
There is a half-inch 14° dovetail bit included, with bearings on it, look close David it is in the picture -- E J ------- Always Keep a Firm Grip on Your Tool |
#7 posted 05-18-2011 05:04 AM |
I was looking at this too. I can live with replacing the bit.. IMO it looks worth a try for $40. -- "Measure Once, Curse Twice" |
#8 posted 05-18-2011 05:07 AM |
General Tools 860 dovetailer EZ Pro dovetail Jig -- E J ------- Always Keep a Firm Grip on Your Tool |
#9 posted 05-18-2011 05:24 AM |
oh yeah… it has been awhile since i used this. i forgot to mention i added a second bearing to the router bit because i wasnt comfortable with the way it looked. a second bearing was like $0.10 btw the jig will do through dovetails but you have to buy a different bit then the one it comes with and the pins are rounded so it doesnt quite look right. works great for half blind dovetails though |
#10 posted 05-18-2011 05:36 AM |
Mike Gager I downloaded the manual, from general tools website, it shows in there to use a spacer to avoid rounding over the tales -- E J ------- Always Keep a Firm Grip on Your Tool |
#11 posted 05-18-2011 05:38 AM |
Yeah I saw the bit bearing, but the post said “2 uses then the bearing starts to just disinegrate, the jig becomes sloppy and just not a pretty sight” and I was/am having trouble visually following cause and affect here. Wow, the bit bearing is cheesy ? I never thought about that. Honestly, I have never had a router bit bearing disintegrate. I usually have good ones that either get dull or rarely used… nothing in between. Huh. And when they disintegrate they make the jig sloppy? I’ll be having me one of these. If I get my four drawers I need out of it, I’ll call it even. -- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia |
#12 posted 05-18-2011 09:33 AM |
I bought this from Harbor Freight. With a 20% off coupon, it was about $25. It only does half DTs, but several different sizes can be made using templates purchased from Grizzly. I think box joints can be made too, but I’m not sure . |
#13 posted 05-18-2011 03:51 PM |
Tedstor I have seen this ,and it looks like it is not a bad jig for the Bucks -- E J ------- Always Keep a Firm Grip on Your Tool |
#14 posted 07-10-2011 08:25 AM |
I think my attraction to this cheap jig is that it can be used at the router table or with the freehand router brought to it. Most can’t do the router table thing. Also, it does dovetail and box joints, half blinds and full through. It will do wider than 6” but not at one setup, but easy to do. 6” will do my drawers most of the time. 12” will do them all. It is made of machined aluminum that is 1/2 inch thick and 1/4 inch thick. The only plastic is the depth gauge, clamp feet and the alignment tool. If it lets me use the router table and does a good job, then I’ll get good quality dovetail bit and box bit for it. Would you really expect a General router bit to be any good ? Just like great tablesaws and bandsaws come with crap blades, we toss them immediately and go get our $100 Woodworker II or whatever. Yeah, I got one today and will post a review with pics after I use it awhile. And if it IS crap, I’ll try to put a scratch and sniff on one of the pics (meaning I’ll tell it like it is). -- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia |
#15 posted 07-10-2011 02:30 PM |
The whole problem with jigs of this nature is the setup and maintaining that. I had one of the entry level jigs about 25 years ago and it worked ok but was time consuming, it didn’t have the cam locks so you had to crank knobs all day. That and it didn’t take long before some ‘play’ showed up. Each piece of it didn’t feel like it had much lost motion, but at the end of the cut those little variences ‘stacked’ as it’s called and the work did not line up as it should. The wider the work the worse it got. -- A TOOL JUNKIE- There, I just admited it to myself... |
Forum | Topics |
Woodworking Skill Share
12027 |
Woodturning
2105 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4902 |
6691 |
28043 |
CNC Woodworking
211 |
Hand Tools
5404 |
Jigs & Fixtures
1417 |
Wood & Lumber
6230 |
1387 |
Focus on the Workspace
2153 |
1186 |
Woodworking Trade & Swap
4754 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8844 |
