Lamps On Marble or Stone Countertops
Forum topic by Sawkerf posted 734 days ago 2152 views 0 times favorited 11 replies Add to Favorites Watch
View Sawkerf's profile
Sawkerf
1776 posts in 1235 days
734 days ago
I’m doing a design/build of a built-in cabinet for a customer who wants to use table lamps on it. They want a marble or granite top and we need to decide how to get the cords into the cabinet as unobtrusively as possible.
The simplest solution is holes thru the top, but that’s also very permanent. Anyone ever had to do this and have a better solution?
11 replies so far
View Jack_T's profile
Jack_T
621 posts in 1198 days
#1 posted 734 days ago
If the cabinet is built in does the electric code in the customer’s area allow for an outlet inside a cabinet? That is rather unusual.
-- Jack T, John 3:16 "For God so loved the world that he gave his only Son, so that everyone who believes in him might not perish but might have eternal life."
Sawkerf
#2 posted 734 days ago
It’s “built-in” only in that it will have baseboard tied into the room baseboard. This is pretty common for entertainment centers, and this is being designed to allow that someday.
View mrg's profile
mrg
483 posts in 1166 days
#3 posted 734 days ago
Depending on where the lamps are going to sit, you could have two gooves cut on the back lip tthen drill a hole in the back of the cabinet. Or dish the the back of the topand drop cord down the back and run the plug into the cabinet.
-- mrg
Jack_T
#4 posted 734 days ago
I understand now. I was thinking along the lines of a counter.
View Dabilene's profile
Dabilene
21 posts in 858 days
#5 posted 734 days ago
I recently visited a home that had holes drilled through the counters under the lamps. Odd at first, but it worked really well. They were drilled throughout both granite and marble. It is permanent, but it was nice with no cords on the counters.
View Dan Lyke's profile
Dan Lyke
1366 posts in 2292 days
#6 posted 731 days ago
I don’t know how tech savvy you are (or how well heeled your clients are), but I instantly thought that some of the new wireless power technologies, like eCoupled, paired with some LED bulbs, could get you lights that worked if they were on the right place on the shelf.
If I were chasing this down, I’d see if I could get some sample coils from Leggett & Platt - eCoupled and put something together. Heck, if you play it right you might even be able to take this to them as a product need.
Oooh, here we go: the WiTricity Developer's Kit, comes with an LED light, assumes the antenna 15-30cm from the receiver. If the LED isn’t enough, it looks like it comes with a couple of “Wireless energy capture modules”. If you can’t source enough current to get as much light as you’d like, maybe you can just assume a lower duty cycle (ie: the lamps are only on a few hours every day) and charge batteries the rest of the time that the lights use when they’re on…
(Yes, I am a geek who’s willing to go way over the top to find absurd solutions to problems…)
Dan Lyke
#7 posted 731 days ago
Looking further, those dev kit receivers appear to have Mini- or Micro-USB jacks on them. That suggests that you might be able to source up to 500mA from them. Looks like a 3v 20cd white LED sinks about 350mA, so their receiver pad, a 47 Ohm resistor and one of those would be a light. Or you could buy complete USB light assemblies for a few bucks and use ‘em in whatever lamps you had in mind…
View 000's profile
000
3352 posts in 783 days
#8 posted 731 days ago
I saw a job fitting your description once. The artist sold the set for a boatload.
The artist didn’t just design the table he did the lamps as well and even insisted on their placement on the tables. So the artist put holes in the tops through which to put the cords and fixed the lamps to the table permanently.
Sort of a Frank Loyd Wright attitude about where the lamp was intended to go.
-- When the moderator chooses sides, his site sucks.
Jack_T
#9 posted 731 days ago
Dan that technology is awesome.
View willme's profile
willme
3 posts in 228 days
#10 posted 228 days ago
i dont think that without doing hole in cabinet it is going to happen, have you tried to attache the wire outside of cabinet.
_
indian stone paving at best price
-- indian stone paving at best price
View adivol's profile
adivol
2 posts in 222 days
#11 posted 222 days ago
Well, option can vary according to the placement of lamp but it’s up to you to decide, what to do? Hole in a cabinet is a best option so far.
granite paving slabs for you
