Any issues with using cedar for a "box" ???
Forum topic by 1yeldud1 posted 05-16-2011 08:06 PM 998 views 0 times favorited 4 replies Add to Favorites Watch
View 1yeldud1's profile
1yeldud1
301 posts in 3067 days
05-16-2011 08:06 PM
Will I run into any problems building and finishing a small box made of cedar for a customer ?? She is requesting it built of cedar – any suggestions as to glue and finish – the majority of my boxes have been built of oak using tight bond 2 for glue and watco danish oil for finish – finger joints, mitre joints are what I usually use – any lumberjocks want to give me suggestions ?
View Gary's profile
Gary
9333 posts in 3458 days
#1 posted 05-16-2011 08:15 PM
I just answered this on another post…. no problems. Use the same techniques you use for the oak. Softer wood, remember that when you clamp.
View gfadvm's profile
gfadvm
14940 posts in 2715 days
#2 posted 05-17-2011 05:01 AM
Applying poly or lacquer over eastern red cedar hasnt worked for me as something in the cedar[oil?] continues to seep through the finish sticking the lid shut months after finishing. Western or white cedar stains and finishes with no unusual problems. Titebond 2 seems to work fine on all types of cedar.
View devann's profile
devann
2246 posts in 2717 days
#3 posted 05-17-2011 06:48 AM
The guys above have about covered it, cedar is soft and easy to leave a mark or dent. I don’t know about finger joints for the corners, miters would probably be better. Seeing how you’re acustom to oak here is a joint that I’ve been wanting to try. I think that you can make the spline from oak and machine the cedar to get some corners like this. This is a box by another LJ that I saw and added to my favorites list.
http://lumberjocks.com/projects/46721
View Jim Finn's profile
Jim Finn
2657 posts in 2947 days
#4 posted 05-23-2011 01:00 AM
I make many small, eastern cedar, boxes. In order to keep the finish from getting on the inside, or on the edges of the box and lid I completly finish them before cutting the lid off, and then install the hinges.
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
