Question on making a Frame and Panel cabinet door using hand tools
Forum topic by funchuck posted 05-16-2011 12:09 PM 5346 views 0 times favorited 7 replies Add to Favorites Watch
View funchuck's profile
funchuck
119 posts in 3176 days
05-16-2011 12:09 PM
Topic tags/keywords: hand tools cabinets frame and panel
Hi Everyone,
I am a long time power tool user, but I just became interested in hand tools. I don’t know why, but planing wood has some kind of theraputic effect on me. Plus, it is much quieter, and I don’t have to wear a respirator.
I still use my 6” power jointer, planer and table saw to dimension the wood, but I want to use hand tools as much as possible.
My question is, I know there are router bits (such as the ogee frame and panel set) that create mating pieces so that the profile of the stile meets the mating piece at the end of the rail. Is there a way to do this using hand tools? Perhaps a specialized one? Is there one that can accomodate curves?
I saw on the lee valley site, that there are some asian hollow and round planes. Would these do the trick? Would there be something easier, that can go around curves? Or, is this only in the realm of the router?
Thanks,
-Chuck
-- Charles from California
7 replies so far
View WayneC's profile
WayneC
13771 posts in 4216 days
#1 posted 05-16-2011 05:28 PM
There are all kinds of antique molding planes that originally did this type of work. You can buy them or make your own. I would say that fellow Lumberjock Phil Edwards is an expert in this area. Here is a link to his web site
http://www.phillyplanes.co.uk/index.php?option=com_content&view=article&id=11&Itemid=22
Here is an example of these planes on eBay…
http://cgi.ebay.com/large-mega-LOT-WOOD-MOLDING-PLANES-ohio-sandusky-tools-/200607093520?pt=LH_DefaultDomain_0&hash=item2eb51d5310
There are a number of books on this topic and Lie-Nielson makes blades can be uses for these types of planes.
My favorite book about how to restore and use them is
http://www.amazon.com/Restoring-Tuning-Using-Classic-Woodworking/dp/080696670X/ref=sr_1_2?ie=UTF8&s=books&qid=1259962527&sr=8-2
A recommended book on how to make them is
http://www.amazon.com/Making-Traditional-Wooden-Planes-Whelan/dp/1879335697/ref=pd_sim_b_12
View Loren's profile
10477 posts in 3766 days
#2 posted 05-16-2011 06:07 PM
For making profiles going around curves you hack away the
excess with knives, chisels and rasps then make the profile with
a scratch stock.
If the curve is constant the profile can be cut with a custom-made
plane for the job. Study coopering tools and you should get the
idea. Also look at coachmaker’s planes which were used for
cutting rabbets in all sorts of bizarre curved surfaces.
If you want to make your own profiles on straight stock start
with some moulding planes. Get a few cock-bead planes,
coves and round-over planes. Things like that. They work
best on softer, straight-grained wood. Most lack a chipbreaker
and trying to cut wiley hardwoods with them will have
you pulling your hair and gnashing your teeth.
WayneC
#3 posted 05-16-2011 06:19 PM
I forgot to add combination planes such as a Stanley #45 to the list…
http://www.supertool.com/stanleybg/stan6.htm
View Bertha's profile
Bertha
13550 posts in 2812 days
#4 posted 05-16-2011 06:20 PM
I agree with the molding recommendations above, particularly with Phil Edward’s planes. You might also consider a combination plane. Although not as sexy as a wood-bodied molder, the 45 works quite well for some of these cuts. And like Loren notes, it’s got some heft. I know EXACTLY what you’re talking about. If there’s a way to make it by hand, I’d probably rather.
13625 posts in 3459 days
#5 posted 05-16-2011 06:40 PM
check the pictures in dennis’s post
they are further down
but maybe give you an idea
of what these tools look like and how they work
http://lumberjocks.com/Dennisgrosen/blog/23236
funchuck
#6 posted 05-17-2011 12:43 AM
Wow, thanks for all the info! It’ll take some time to absorb all of this, but it looks like I can buy some old ones, or even build my own. The “Making Traditional Wood Planes” book sounds interesting. I might have to buy that one.
View canadianchips's profile
canadianchips
2602 posts in 3115 days
#7 posted 05-17-2011 01:56 AM
You can try using a stanley #48 or #49 for making stile and rails. They are designed for matching tongue and groove boards. I have a wooden moulding plane that will give the profile of the panels you need inside. The old tools are there, just keep looking. (My biggest drawback is I am so outta shape to do to much of this hand work) I do a combination of power and hand tools.
