| Forum topic by jonasramus | posted 740 days ago | 789 views | 0 times favorited | 4 replies | ![]() |
740 days ago |
Ok fellas, I bought a used DJ-20 and am trying to tune it up. The infeed and outfeed tables are significantly out of alignment, more than can be adjusted with the eccentric cams. What gives? The infeed table moves a bit if I lift the edge opposite the blades, and so I’ve been looking for some place to tighten something. I tried loosening and retightening the parallel bars that are near the infeed adjustment handle, but this didn’t help. The corresponding bars near the knives are my next option but they are very hard to get to since I will have to lift the whole cast assembly off the frame to access them. I’m not looking forward to that. Did I buy a lemon or are there more dramatic adjustments that can be made than can be accomplished with the cams? Is adjusting these bars a viable option? -- Jeff, Deltona Florida |
