titebond 3 problems when in the sun?
Forum topic by rfuller posted 05-16-2011 12:36 AM 2918 views 0 times favorited 10 replies Add to Favorites Watch
View rfuller's profile
rfuller
5 posts in 2755 days
05-16-2011 12:36 AM
I have been making cutting boards and selling them at local shows for the past year. I us walnut, cherry, and maple in most of my boards and us titebond 3 for glue. Now that the weather is getting warmer I am noticing problems with my glue joints. At shows I am having to move my boards around and flip them over all the time to keep the joints from turning white. It looks like it would if you glued up under 50 degrees and the glue chalked up. This happens mainly in the walnut boards because they are getting hotter from there dark color in the sun. Anyone else ever have this problem? Does this cause a problem in the strength of the glue joint? Any solutions?
-- Robin
10 replies so far
View Miles King's profile
Miles King
28 posts in 2596 days
#1 posted 05-16-2011 03:11 AM
Go to titebond web site and they clearly say for type III: Chalk temperature approx. 47°F. Like my daddy said – Boy you need to read all the writing.
Miles.
-- Miles
View Obie's profile
Obie
24 posts in 3004 days
#2 posted 05-16-2011 03:18 AM
Oh dang.. i didn’t even know that happened.
-- "Measure Once, Curse Twice"
rfuller
#3 posted 05-16-2011 06:11 AM
I am not having this problem during colder temps. It is 80 plus outside and in direct sunlight. The problem comes up if them get to warm or hot from the sunlight. From some more research I think it might have something to do with glue creep.
-- Robin
Miles King
#4 posted 05-16-2011 04:54 PM
Perhaps I didn’t understand the warning on their web site. I thought the meaning of the warning is that if you applied the glue at temperatures at or below 47 degrees chalking could take place.
Miles.
-- Miles
rfuller
#5 posted 05-16-2011 05:40 PM
Chalking does happen at colder temps i have had that happen as well. The boards I have had problems with where built in temps between 60 to 75 degrees. After looking for some more info online last night I thinks the glue is creeping out and then the part that creeped out is turning white. So i guess my questions now is why is if titebond 3 dries brown why is the part that creeps up turning white. Could it be a UV problem?
-- Robin
View bubinga's profile
bubinga
861 posts in 2571 days
#6 posted 05-16-2011 05:41 PM
Use dark wood glue for walnut.
-- E J ------- Always Keep a Firm Grip on Your Tool
View ajosephg's profile
ajosephg
1880 posts in 3465 days
#7 posted 05-16-2011 08:08 PM
Sounds like a phone call to Titebond is in order. Let us know what they say.
-- Joe
View Bill White's profile
Bill White
4853 posts in 3864 days
#8 posted 05-17-2011 05:33 PM
Use a polyurethane glue. Read all the instructions about clean up.
Bill
-- bill@magraphics.us
View SteveMI's profile
SteveMI
1078 posts in 3198 days
#9 posted 05-26-2011 04:05 AM
I second the comment Joe made above and let us know what they say.
Steve.
View mrg's profile
mrg
804 posts in 2903 days
#10 posted 05-26-2011 05:43 AM
How old is the glue? The shelf life is 12 months.
-- mrg
