Your favorite Waterlox finishing method
Forum topic by Cjcorrell posted 04-06-2018 11:35 AM 824 views 0 times favorited 16 replies Add to Favorites Watch
View Cjcorrell's profile
Cjcorrell
12 posts in 263 days
04-06-2018 11:35 AM
So I am getting ready to finish my walnut dining table and I was wondering what your guys favorite Waterlox finishing method was. I’ve heard lots of different methods as far as brush on, wipe on, combination, whether to buff out after cure, etc.
Thanks
16 replies so far
View Firewood's profile (online now)
Firewood
520 posts in 1831 days
#1 posted 04-06-2018 01:53 PM
I like to wipe it vs brush, etc. I will sometimes make a pad from old t-shirt material and put it in a piece of stocking. But on bigger pieces, I will finish the coat I’m applying by opening the material and hold the corners and drag it across the surface. Obviously, this is only good for horizontal surfaces. I like to buff it out some, but it depends on the desired sheen.
-- Mike - Waukesha, WI
Cjcorrell
#2 posted 04-06-2018 01:59 PM
I like to wipe it vs brush, etc. I will sometimes make a pad from old t-shirt material and put it in a piece of stocking. But on bigger pieces, I will finish the coat I m applying by opening the material and hold the corners and drag it across the surface. Obviously, this is only good for horizontal surfaces. I like to buff it out some, but it depends on the desired sheen.
- Firewood
Does wiping it require more coats to build a finish?
Firewood
#3 posted 04-06-2018 02:39 PM
Yes. Wiping coats are considerably thinner than brushing, but it avoids runs. For a table top, you’ll want a good build up, so brushing the first couple coats may help speed up the process for you.
Sanding between coats is only needed to remove any dust nibs. Waterlox will blend in with the previous coat without sanding.
Don’t get discouraged with the first couple coats. They may not meet your initial expectations, but by the 3rd coat you should start to see a significant improvement.
Cjcorrell
#4 posted 04-06-2018 04:08 PM
Yes. Wiping coats are considerably thinner than brushing, but it avoids runs. For a table top, you ll want a good build up, so brushing the first couple coats may help speed up the process for you.
Don t get discouraged with the first couple coats. They may not meet your initial expectations, but by the 3rd coat you should start to see a significant improvement.
- Firewood
So if I brush the first few, as far as the brush goes, I’ve read that a natural bristle brush is the thing to use. If so, is it readily available at home centers, or should I go to somewhere local like woodcraft for a better quality one?
View OSU55's profile
OSU55
1958 posts in 2187 days
#5 posted 04-06-2018 04:26 PM
Depends on which Waterlox product is used – urethane requires sanding. Badger hair brushes are supposedly the best, but expensive. I like taklon brushes. Tho synthetic, they work well with varnish. Otherwise the finest bristle natural hair brush you can find, and the bbs probably wont have it.
Firewood
#6 posted 04-06-2018 04:41 PM
OSU55 is correct. My bad. I’ve only used the original formula and made a poor assumption.
View YesHaveSome's profile (online now)
YesHaveSome
128 posts in 456 days
#7 posted 04-06-2018 05:37 PM
- Firewood
I am using Waterlox for the first time on some walnut shelves I am making. It’s not going well. I am 5 coats in (wiped) and it’s got a lot of shiny spots. I was sanding with 400 between coats but stopped that after two. Last night I decided to test an area by giving it a pretty decent sanding with 320. The overall finish improved but I still had shiny spots. Gonna keep applying coats and see what happens. Finishing is not my strong suit and I am regretting not just using polycrylic.
-- But where does the meat go?
View ppg677's profile
ppg677
209 posts in 1053 days
#8 posted 04-06-2018 06:12 PM
I use a foam brush. Light sanding between coats. 0000 steel wool over last coat.
I’m happy with the results.
But the fumes are super super nasty and I’ll never use it indoors again.
View Rich's profile
Rich
3871 posts in 787 days
#9 posted 04-06-2018 06:13 PM
I am using Waterlox for the first time on some walnut shelves I am making. It s not going well. I am 5 coats in (wiped) and it s got a lot of shiny spots.
- YesHaveSome
What do you mean by shiny spots? Waterlox Original (which I assume is being referred to when someone simply says Waterlox) goes on with about a 75 sheen. That’s pretty glossy. Were you expecting something else?
As to the OP, I have found I prefer using a good quality foam brush (they do exist). It lays down a good coat without brush marks. If you really want a perfect finish, spray your last coat, maybe two.
Cjcorrell
#10 posted 04-06-2018 06:30 PM
I m happy with the results.
But the fumes are super super nasty and I ll never use it indoors again.
- ppg677
Using the 0000 steel wool after the 30 days full cure or just 24hrs after last coat?
View BorkWood's profile
BorkWood
14 posts in 250 days
#11 posted 04-06-2018 07:39 PM
I use a papertowel/shop rag wrapped in a t-shirt or something to wipe on. Several coats and then buff to desired sheen with scotchbrite pad. I’ve only done this with the original, have a gallon of the Marine sealer and finish that I’m getting ready to try on an outdoor table top.
-- Matt, Woodworker based in NC, https://www.BorkWoodBlog.com
Cjcorrell
#12 posted 04-06-2018 09:11 PM
I use a papertowel/shop rag wrapped in a t-shirt or something to wipe on. Several coats and then buff to desired sheen with scotchbrite pad. I ve only done this with the original, have a gallon of the Marine sealer and finish that I m getting ready to try on an outdoor table top.
- BorkWood
So how many coats is several when using wipe on method? I know they recommend 3-5 when brushing on, but I also know using wipe on is harder to build a finish.
ppg677
#13 posted 04-06-2018 09:41 PM
- ppg677
- Cjcorrell
I just waited a couple days. The steel wool makes it nice and smooth and cuts down the luster slightly
View bonesbr549's profile
bonesbr549
1576 posts in 3264 days
#14 posted 04-06-2018 11:24 PM
I always sprayed.
View TungOil's profile
TungOil
1055 posts in 692 days
#15 posted 04-08-2018 02:32 AM
I use Waterlox quite a bit. It is one of my go-to finishes for smaller pieces, especially cherry. I prefer to wipe it on using cheesecloth. Wiping will take more coats and as mentioned above the first two will look terrible. I wait 24 hours between coats and lightly scuff with 320 between coats to denib. 6 coats usually does it for me. wait about 2 weeks or more before rubbing out with steel wool if you want to cut the sheen, but be aware that the sheen will dull over the first 6 months on its own.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
