Porter Cable 690LR Router enough power for raised panel bits?
Forum topic by yellowtruck75 posted 741 days ago 1759 views 0 times favorited 13 replies Add to Favorites Watch
View yellowtruck75's profile
yellowtruck75
329 posts in 1240 days
741 days ago
I am looking at buying Rocklers new router table combo that comes with the Porter Cable 690LR Router. I want to be able to make raised panels in the future and want to make sure that this router won’t hold me back in that. I have been told that raised panel bits are the biggest and hardest to route with so thats why I am asking about them.
Thanks
http://www.rockler.com/product.cfm?page=30659
13 replies so far
4901 posts in 1821 days
#1 posted 741 days ago
It’ll do it.
You can cut off most of the waste with the table saw first and
then the router doesn’t have to work as hard, the cut goes faster,
and there’s less mess.
View cut3times's profile
cut3times
115 posts in 1179 days
#2 posted 741 days ago
I have used one for raised panels and had no problems. Make sure you buy quality bits which puts less drag on the motor.
Jerry
-- And Still Too Short - "Life is what happens to you while you're busy making other plans." John Lennon
View knotscott's profile
knotscott
4216 posts in 1548 days
#3 posted 741 days ago
It’ll do it, but it’ll struggle more than a router with a larger motor, which in turn will shorten it’s service life. The 690 is better suited as a hand router or table router for smaller bits IMO…..can’t help but think you’d be better served with a 13-15 amp router if you’ll be doing very many raised panels.
yellowtruck75
#4 posted 741 days ago
Don’t think that I will be doing a ton of work with raised panel so I am going to go with that package. Just wanted to make sure that I wouldn’t be held back for future projects.
Thanks
View D_Allen's profile
D_Allen
495 posts in 957 days
#5 posted 741 days ago
I have one and have used it a lot for raised panel and everything else.
2 things to remember.
1 – don’t try to take too much on each pass
2 – check the router after extended use and see if you need to give it a break and cool down.
This is actually good advise on any router.
-- Website is finally up and running....www.woodandwrite.com
knotscott
#6 posted 741 days ago
It just occurred to me that the 690LR doesn’t have variable speed. You won’t want to spin a 3” raised panel bit at 20K+ rpms. If you end up with the 690LR, you’ll either want to add a speed control or use a vertical panel raising bit.
View brianlee's profile
brianlee
18 posts in 773 days
#7 posted 741 days ago
knotscott is correct. Don’t use a large diameter bit in a single speed router. Too dangerous.
D_Allen
#8 posted 741 days ago
OOPS! My bad. Mine is variable speed so it is a 690LRVS.
Sorry about that!
View SSMDad's profile
SSMDad
402 posts in 770 days
#9 posted 741 days ago
garyp is right although the one issue I have with the Bosch router (I just recently returned at 1617evs) is that while they are wonderful pieces of equipment. Something as simple as a PC compatible guide bushing needs 2 different adaptors to use. One of which you can’t even buy from Bosch’s website.
Dunno why Bosch couldnt have just included the d* $7 adaptor instead of making people have to try to track one down.
-- Chris ~~Who controls the past controls the future. Who controls the present controls the past."
View Jerry's profile
Jerry
1431 posts in 1720 days
#10 posted 741 days ago
I agree the 690, which is 1.75 HP, without variable speed is the wrong router for a panel raising bit. The 690 is a great router and buying this router will give you plenty fun routing experience. Plus getting this router will give you good justification to add another router to your collection down the road whenever you decide to raise panels.
-- Jerry Nettrour, San Antonio, www.topqualitycabinets.net
View bubinga's profile
bubinga
867 posts in 840 days
#11 posted 741 days ago
You might want take a look at this router table,but does not come with a router, can’t hurt to look
http://www.rt1000.com/index.html
-- E J ------- Always Keep a Firm Grip on Your Tool
brianlee
#12 posted 740 days ago
O.K., since you have the variable speed router you should be fine. The biggest problem with underpowered tools, whether it’s a router or a table saw, is you have to adjust your technique to the tool. With a higher HP router, you could run a panel through in one pass if inclined. But with your 690, you will have to make several passes or hog out some of the waste on a table saw as Loren suggested—which is the method I would use if using a 690. If you tried to cut a panel in one pass on a 690, I can almost guarantee you’re going to burn the wood. So it can be done, but it will require more steps and take more time. If you’re doing small projects it’s not that bad, but it can be a real PITA if you had a lot of projects to do.
bubinga
#13 posted 740 days ago
brianlee
D_Allen is the one with the variable speed router, not the poster,yellowtruck75
A PC ,690 ,is a good router to have in every shop
