Thickness planer
Forum topic by Dabcan posted 05-14-2011 04:20 PM 1344 views 0 times favorited 4 replies Add to Favorites Watch
View Dabcan's profile
Dabcan
255 posts in 2868 days
05-14-2011 04:20 PM
Topic tags/keywords: thickness planer ridge rigid question
I picked up a rigid thickness planer (4330) a week ago and have been fairly happy with the results. I don’t have much experience with a planer so I was hoping for some guidance. I try to vary where I feed the pieces in order to even out the wear on the blades, however when I run a piece on the right hand side, it always comes out smooth with a thin ridge on it? I haven’t used the planer all that much in the last week so I am wondering if I have a knick out the blade or could there be some debris stuck inside?
Thanks.
-- @craftcollectif , http://www.craftcollective.ca, https://www.etsy.com/shop/craftcollective?
View RickLoDico's profile
RickLoDico
55 posts in 3258 days
#1 posted 05-14-2011 05:11 PM
There’s a nick in one of the blades. Move any one of them just a hair and you should be fine. I don’t even bother with my “ridges”. They come out when sanding.
-- He who fights with monsters might take care lest he thereby become a monster. And if you gaze for long into an abyss, the abyss gazes also into you.
View SouthTexan's profile
SouthTexan
2 posts in 2851 days
#2 posted 05-14-2011 08:04 PM
+1 to what RickLoDico says…..I sand the ridges out also as the blades still cut very well even though they have a few nicks in them…..Dewalt 734…
Scott
-- If you never take a shot you will miss 100% of the time..."Wayne Gretzky"
View TJU's profile
TJU
72 posts in 2853 days
#3 posted 05-14-2011 08:33 PM
Ditto on what they said.
Nicks are no big deal you have to sand anyway and they come right out. If you don’t sand you will see the blade scalups after you put on the finish. It should be a good planer I hope you like it. If you don’t have a jointer you can make a planer sled to mill up your lumber.
Tim
-- Although the voices aren't real they have some pretty good ideas.
View knotscott's profile
knotscott
8144 posts in 3572 days
#4 posted 05-14-2011 09:04 PM
The blades are reversible so you can swap sides on one or all of the blades to eliminate the ridges, but nicks are plenty common and are pretty much inevitable, so they’ll be back. You can remove the ridges several ways….by running board back thru the planer at the same height in a different location, sanding, or using a handplane or scraper.
