| Forum topic by Alan S | posted 766 days ago | 3969 views | 2 times favorited | 17 replies | ![]() |
766 days ago |
LOML was sweet enough to buy me an HVLP system for my birthday. Up to this point, I’ve wiped on arm r seal and had good results. I would love to speed up the finishing process (a day instead of a week) but still have a durable surface. What specific products would you suggest and where can I buy them? Thanks! Alan |
17 replies so far
#1 posted 766 days ago |
Sounds like lacquer to me, get aquainted with it, run a few tests, get a good solvent filter mask and get ready for one day finishes |
#2 posted 766 days ago |
I know Arm R Seal adds an amber color to raw wood and I’ve heard people complain that water based poly does not. Does lacquer add an amber color like the oil based varnishes? Thanks! Alan |
#3 posted 766 days ago |
Lacquer and oil base varnish will yellow over time. If you do not, then use water based poly. -- shdesign3.com |
#4 posted 766 days ago |
Since I have a basement shop, I only spray Target 6000 water base lacquer with great results. -- Uncle Fester |
#5 posted 766 days ago |
Zinsser Bulls Eye Seal Coat adds an amber color ,and pops the grain,then you can use fast drying water based poly , and it looks great -- E J ------- Always Keep a Firm Grip on Your Tool |
#6 posted 766 days ago |
I love to spray minwax and general finishes water born poly acrylic finishes. If you have a membership to FWW here is a good article. http://www.finewoodworking.com/Materials/MaterialsPDF.aspx?id=27123 The thing I like the best is how fast it dries. I can put on several coats in one day with sanding in between. It does take a few weeks to fully cure. The down side is the grain raising but if you are going to sand between coats anyway it’s not any more work. I usually put on 3-4 coats. If you are interested in all my steps and how I mix in the color just let me know and I can post it. Tim -- Although the voices aren't real they have some pretty good ideas. |
#7 posted 766 days ago |
Water based poly designed for spraying from Target Coatings, ML Campbell, etc., are easy to spray, easy to clean up, and very durable. With moderate temps and humidity, you can easily do multiple coats in a day. They are pretty much water white, so you’ll need to do something else for color. |
#8 posted 766 days ago |
TJU Thanks for pointing me to the article I am a member -- E J ------- Always Keep a Firm Grip on Your Tool |
#9 posted 766 days ago |
Is there a good book or DVS that covers spray finishing? Charles Neal has a series of DVD’s. Has anyone seen it. Domer |
#10 posted 766 days ago |
Post catalyzed conversion varnish is a great, durable finish. It provides a slight warm amber tone and I’ve not had any problems with yellowing. I use ML Campbell Duravar on just about everything except really high-end hand rubbed furniture. The conversion varnish is a burn-in finish (like lacquer) and you can easily apply 3 coats to both sides of a part in about 4 hours elapsed time. It is advisable to spray on horizontal parts as you get a good even flow and great leveling. Don’t go with more then 3 coats or you can get crackling in the finish. Cleanup is with lacquer thinner. HVLP is the best way to apply this finish. -- Don, Diamond Lake Custom Woodworks - http://www.dlwoodworks.com - "If you make something idiot proof, all they do is make a better idiot" |
#11 posted 765 days ago |
You did not tell us about the spray environment. Indoors /outdoors, what? If you’re usin’ NC lacquer, you’d better have a way to protect from the big boom when all those fumes build up and somebody flips a light switch. -- bill@magraphics.us |
#12 posted 765 days ago |
Lacquer wins hands down. -- "The way to make a small fortune in woodworking- start with a large one" |
#13 posted 765 days ago |
Lacquer is an all around better finish but when you have to spray your projects by the window in your shop Lacquer is not always the better choice. If I had a spray booth with good ventilation I would use more lacquer, but it’s not even an option for me in the winter when its 20 deg. outside. Water based poly is also easier to clean up. Sometime you sacrifice what is better for what is more convenient (and just because it’s convenient doesn’t mean it’s not good). If I had a good spray booth with good ventilation I would use more lacquer. Tim -- Although the voices aren't real they have some pretty good ideas. |
#14 posted 765 days ago |
You guys are amazing! Thanks for the great responses! My shop is a two car attached garage. I was thinking of spraying with the garage door open, maybe with a tarp hanging to make a three sided booth and spraying from outside. Possible? |
#15 posted 765 days ago |
I’m not an accomplished sprayer but I’d echo Cessna’s concerns. I’ve had rags spontaneously burst into flames. If anyone thinks this is legend, I’ll gladly share the details:) -- My dad and I built a 65 chev pick up.I killed trannys in that thing for some reason-Hog |
| Forum | Topics |
Woodworking Skill Share
8842 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
68 |
Joinery
96 |
Finishing
1597 |
3591 |
15972 |
Hand Tools
2093 |
Jigs & Fixtures
501 |
Wood & Lumber
2905 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2772 |
LumberJocks.com Site Feedback
1551 |
Coffee Lounge
6130 |
