Tackle box - finishing
Forum topic by john_ela posted 05-13-2011 04:04 AM 2122 views 0 times favorited 10 replies Add to Favorites Watch
View john_ela's profile
john_ela
2 posts in 2564 days
05-13-2011 04:04 AM
Hello – I’m new to woodworking and have started to plan out a basic wooden tackle box for my first project. I plan on actually taking it fishing with me, where it will be exposed to some moisture or splashes of water at times.
Can someone recommend how to seal and protect the wood? (using some old pieces of walnut).
Thanks,
-John
10 replies so far
View Steven H's profile
Steven H
1117 posts in 3053 days
#1 posted 05-13-2011 08:07 PM
Waterlox would be an excellent choice. It is MORE water resistance than spar varnish
I like to use apply thung oil on bare wood, then apply waterlox 3 coats.
Tung oil is more water resistance than boiled linseed but not much.
john_ela
#2 posted 05-14-2011 12:54 PM
Steven – thanks! I read up about waterlox on their website and this seems perfect. Appreciate your help.
View hObOmOnk's profile
hObOmOnk
1381 posts in 4121 days
#3 posted 05-14-2011 01:08 PM
Spar varnish would be a good choice, as would any good exterior polyurethane enriched varnish.
-- 温故知新
View ScottN's profile
ScottN
261 posts in 2673 days
#4 posted 05-14-2011 01:59 PM
I would like to see some pics when your finished.
I would also go with tung oil. Apply some wax once a year for maintaining finish and waterproofing.
Polys fail after a year or two; clear coatings with UV last about twice as long.
-- New Auburn,WI
Steven H
#5 posted 05-14-2011 04:29 PM
You would think that because it is meant for exterior use where water and sun hits it. But because it contains a higher oil content than interior varnish. It is really meant to be soft and flexing, so therefore it is not durable finish for water resistant.
The phenolic varnish is most water resistance than all other two resin.
hObOmOnk
#6 posted 05-14-2011 04:32 PM
What other two resins?
-- 温故知新
Steven H
#7 posted 05-14-2011 04:40 PM
alkyd resin
polyurethane resin( also known as urethane)
hObOmOnk
#8 posted 05-14-2011 05:50 PM
What’s the difference between alkyd resin and polyurethane resin?
-- 温故知新
Steven H
#9 posted 05-15-2011 01:04 AM
Im going to make a new thread explaining all three resin.
Steven H
#10 posted 05-16-2011 04:11 AM
The most water resistant and most durable finish is an interior rated varnish or poly varnish.
But because waterlox contains tung oil which makes it water resitance it is okay for a tackle box.
