Router guide bushing is too long...
Forum topic by mpounders posted 745 days ago 790 views 0 times favorited 7 replies Add to Favorites Watch
View mpounders's profile
mpounders
598 posts in 1068 days
745 days ago
Topic tags/keywords: question router jig
so can I just sand it off shorter? Someone gave me a cheap Central Machinery dovetail jig and my daughter would like me to make a couple of drawers for a cabinet she is re-doing. I picked up some cheap router guide bushings at Harbor Freight and the bushing that fits the comb on the jig extends a bit past the bottom of the comb. The comb is 1/4” thick aluminum and the bushing is a little longer. I figured that I would mark it while in the jig and then just grind it down so that it would work with a 1/4” thick template. Othe than being maybe 1/16th too long, it seems like it will work fine.
Having never used a bushing, or a dovetail jig, I figured I better ask before making the bushing shorter! Am I on the right path here?
-- Mike P., Arkansas, http://mpounders1.blogspot.com
7 replies so far
View Mark A. DeCou's profile
Mark A. DeCou
1947 posts in 2578 days
#1 posted 744 days ago
Mike, I’ve sanded off guide bushings before, didn’t hurt a thing. I just used a metal cutting file, and made a few quick swipes and it was short enough for the jig I was using.
Mark
-- Mark DeCou - American Contemporary Craft Artisan - www.decoustudio.com
mpounders
#2 posted 744 days ago
Thanks Mark. I will give the file a try first.
Dick, & Barb Cain
8681 posts in 2472 days
#3 posted 744 days ago
I just used a hand hacksaw, and then sanded it smooth. It works fine.
Brass is real tough filing.
View bubinga's profile
bubinga
867 posts in 840 days
#4 posted 744 days ago
I have done this before
I used a die grinder , fine cut file ,and sand paper to smooth it.
-- E J ------- Always Keep a Firm Grip on Your Tool
View Richard's profile
Richard
503 posts in 863 days
#5 posted 744 days ago
And even if you don’t get it perfectly flat it is no big deal as your only useing the sides of the bushing anyway, just need to get it shorter than the template.
Also check out this link for some tweaks to help make adjusting that dovetail jig a little bit easier. The jig is from HF as well.
http://lumberjocks.com/projects/42759
mpounders
#6 posted 744 days ago
Thanks for all the input and especially for some tips on tweaking the jig also….you have probably increased my chances of success!
View Popsnsons's profile
Popsnsons
308 posts in 1154 days
#7 posted 744 days ago
Mike, Could you make an auxilary base plate for your router that is thicker? This way you can keep the guide bushing in tact in case you need to use it as is in the future.
-- Pops ~ In So Cal...
