Barrel hinges for small boxes
Forum topic by robdem posted 05-11-2011 05:50 AM 1798 views 0 times favorited 2 replies Add to Favorites Watch
View robdem's profile
robdem
381 posts in 2842 days
05-11-2011 05:50 AM
Looking to use barrel hinges for some boxes making .Wood is all 1/2 inch thick . Don’t know where to start . Believe wood needs to be cut at a 45 degree angle for top and back piece to match up . Any and all help is welcome thanks guys
2 replies so far
View Kent Shepherd's profile
Kent Shepherd
2718 posts in 3522 days
#1 posted 05-11-2011 04:18 PM
Rockler is a good source for that. They also have other sizes than these.
http://www.rockler.com/product.cfm?page=9838&rrt=1
-- http://shepherdtoolandsupply.com/
View ShaneA's profile
ShaneA
7064 posts in 2835 days
#2 posted 05-11-2011 04:58 PM
The top and back will need to be beveled at 45 degrees in my experience. You want to drill the holes before you bevel the edges. Plus you will want to make sure you have the depth correct for the holes and spaced evenly from side to side and front to back. Can be tricky to line up for assembly.
