I LOOOVE these. Now how do i make them?
Forum topic by Kali2024 posted 05-10-2011 05:37 PM 1613 views 0 times favorited 8 replies Add to Favorites Watch
View Kali2024's profile
Kali2024
29 posts in 2571 days
05-10-2011 05:37 PM
• So what tools would I need to make these? (I found the feet online-but need the rest)
• How would you add the cane? I’m thinking I just would want the cane on the sides not the back.
Thanks in advance.!
https://s3.amazonaws.com/vs-lumberjocks.com/lkzkom0.jpg!
8 replies so far
View richgreer's profile
richgreer
4541 posts in 3072 days
#1 posted 05-10-2011 05:48 PM
You will need a band saw, some carving chisels and a lot of skill. You will also need some sanders and a way to cut mortises and tenons. With respect to the mortise and tenons there are several options. I would probably use a router and a jig for cutting mortises and I would use loose tenons.
Can’t help you on the caning.
View JSilverman's profile
JSilverman
89 posts in 2611 days
#2 posted 05-10-2011 11:37 PM
looks like a lathe for the back/top rail; a band saw (plus the obvious table saw, jointer &planer)
joints likely mortice and tenon so you need some way to do those
not too difficult as far as chairs go… realizing that chairs are not generally easy per se. There are several good books available for general chairbuilding techniques.
I recently finished a set of 10 dining chairs as my initiation into chairbuilding – I would not recommend that approach!!!
Jeff
JSilverman
#3 posted 05-10-2011 11:39 PM
I should have also said that is a gorgeous chair! good luck…
also you will probably want a professional to make those cushions.
10388 posts in 3645 days
#4 posted 05-10-2011 11:54 PM
If just making a few, a bandsaw, a jointer, and a planer will be
useful to you for squaring the parts and cutting the curves. You’ll
need some carving tools, rasps and files for shaping the parts. A
router and a few bits will come in handy.
You’ll need to do the joints in some way. Get set up for dowels
or mortise and tenon.
The cane work is done with sheet cane, which is cheap, held
in place by splines pounded into router channels. Just like a
window screen, really.
View Bertha's profile
Bertha
13528 posts in 2691 days
#5 posted 05-10-2011 11:57 PM
I never get tired of Loren’s comments:) I’d add a lathe to his list for the front feet, unless you want to tackle them with a rasp! :) That’s really an exceptionally cool chair and I usually don’t like cane work. Loren’s right as usual, though, make it!
View SPHinTampa's profile
SPHinTampa
567 posts in 3683 days
#6 posted 05-10-2011 11:58 PM
I am not sure that I have ever seen the exact plans for a chair like this. I might start with a similar design and try to modify it to fit.
The attached plan, for purchase, is for a Morris Type Chair which is structurally similar in some respects:
http://www.finewoodworking.com/PlansAndProjects/PlansAndProjectsPDF.aspx?id=32301
Norm did a cigar chair episode, which is also similar:
http://www.newyankee.com/getproduct.php?0304
A free plan can be found at:
http://americanwoodworker.com/blogs/projects/archive/2008/07/07/Garden-Chair.aspx
An overview of caning can be found here:
http://www.woodstore.net/sesttotrchca.html
-- Shawn, I ask in order to learn
Bertha
#7 posted 05-11-2011 12:01 AM
^the above is why Lumberjocks rules.
View devann's profile
devann
2246 posts in 2690 days
#8 posted 05-11-2011 05:25 AM
That’s a nice chair, the LJs above pretty much covered the tools that you’ll need to build one.
There is a fellow on this site know for his nice chair designs. Type in Scott Morrison in the search box and look on his home page. He also has a website. I’m pretty sure that I’m not the only one on Lumberjocks that he inspires with his work.
BTW, Has you cruz around the site looking at other projects if you see a particular LJ’s projects you like, that’s what the buddies list is for. If they are on your list when they have a new post it’ll show up in your email.
