Variable speed switch for a router
Forum topic by James posted 03-29-2018 11:07 PM 502 views 0 times favorited 8 replies Add to Favorites Watch
View James's profile
James
131 posts in 1991 days
03-29-2018 11:07 PM
Recently I got a Jessem lift. I have a Bosch 1617 EVS in. It. The variable speed setting on the switch does nothing. ON turns the router on at whatever speed the router is currently set on. Can this work somehow?
-- James - Semper Fi
8 replies so far
James
#1 posted 03-29-2018 11:09 PM
Let me clarify. I have an aftermarket variable speed control switch. The router also has a variable speed rolling switch. Sorry for that confusion.
View MrUnix's profile
MrUnix
7053 posts in 2403 days
#2 posted 03-29-2018 11:27 PM
Try it and see. If your router’s slow start function (does it have one?) is still working though, I doubt it will work.
View WyattCo's profile
WyattCo
93 posts in 308 days
#3 posted 03-30-2018 03:45 PM
You need to bypass the variable speed switch on the router if you intend on using an external/separate VSS.
View LesB's profile
LesB
1866 posts in 3647 days
#4 posted 03-30-2018 04:50 PM
I seldom find a need to vary the speed of my routers so an external control is unnecessary, unless you are using a large bit (say over 1 1/4” in diameter) there is little need to slow the router down. A second reason would be the rare chance you are getting a lot of surface burning…. Cherry wood is bad about that and dull bits will also cause it.
If you are removing a lot of wood do it in several passes instead of one deep cut and make a the final pass very thin to get a smooth finish.
-- Les B, Oregon
View Andybb's profile
Andybb
1522 posts in 807 days
#5 posted 03-30-2018 04:52 PM
Yes. The slow start feature on the Bosch 1617 prevents a VSC from working. (Ask me how I know) In practical usage though I have found that I don’t need to adjust the speed very often. As a rule I keep mine just a hair below the max speed and only change it for special situations so my setup allows me access to the speed control on the router by reaching under the table. I think I’ve slowed it down twice in the past year when I was using miter-lock or large raised panel bits.
Edit – LesB is saying the same thing but I wrote it so I posted it.
-- Andy - Seattle USA
View Gene Howe's profile
Gene Howe
11072 posts in 3633 days
#6 posted 03-30-2018 06:58 PM
My router also has VS and it’s mounted in a Jessem lift, too. I’ve never found it to be a problem to operate the VS controller from under the table. Maybe because my table is mounted to the TS and so, it’s a bit higher than normal and, it’s got gobs of room under it.
The best thing I ever did was hook the router to a foot switch.
Andybb
#7 posted 03-30-2018 08:43 PM
- Gene Howe
Yes. Once I realized the $19 harbor freight VSC wouldn’t work I took it back and bought the $13 foot switch.
View MrRon's profile (online now)
MrRon
5203 posts in 3447 days
#8 posted 03-31-2018 10:15 PM
I have a HF VSC on my Hitachi 3-1/4 hp router and it works perfectly. The speed control quit, so I bypassed it with the HF unit.
