Help on Circle cutting Jig + sanding
Forum topic by handyman_pk posted 05-09-2011 10:59 AM 4646 views 0 times favorited 16 replies Add to Favorites Watch
View handyman_pk's profile
46 posts in 3575 days
05-09-2011 10:59 AM
Topic tags/keywords: circle cutting jig question sanding
hi LJs I wanna make Coasters, Is there any way of making with both sides finished no pin hole of circle cutting jig. The both sides will be leaser engraved thats the reason i don’t wanna use the jig with the pin.
-- when you lose, Don't lose lesson
16 replies so far
View William's profile
9949 posts in 2772 days
#1 posted 05-09-2011 11:09 AM
With practice, you’d be amazed at how good you can make circles with a scroll saw. All I ever have to do to a circle is to touch my sander to one spot on the side to get rid of the little nib where the blade starts and finishes around the circle.
#2 posted 05-09-2011 11:30 AM
idea is great for little quantity, I have to make hundreds of them . accurate dimensions required, every batch should be same so they can be placed in laser Engraver one by one at same place
View ellen35's profile
2734 posts in 3362 days
#3 posted 05-09-2011 12:20 PM
My coasters are square…you get more consistency that way.
View Gregn's profile
1642 posts in 2913 days
#4 posted 05-09-2011 01:17 PM
One suggestion might be to turn a blank on the lathe for the size diameter you desire and then slice off the coasters with a band saw.
View Paul Pomerleau's profile
Paul Pomerleau
309 posts in 2623 days
#5 posted 05-09-2011 01:34 PM
I made a video of my circle jig that uses double sided tape.
You can make the square part for the dowel larger to stop the wobble.
You will see what I mean when you watch the video here.
Hope it helps.
-- Close to Ottawa Ontario Canada
#6 posted 05-09-2011 08:15 PM
Neat jig Paul.
View GaryK's profile
10262 posts in 3918 days
#7 posted 05-09-2011 08:22 PM
You could cut out oversized circles and finish turning them on a lathe. Just make a faceplate and pressure plate for the tailstock with sandpaper on the faces.
You could turn your tool rest around and clamp a block of wood to your chisel to act as a stop allowing you to make all you coasters exactly the same diameter.
View Pawky's profile
278 posts in 2734 days
#8 posted 05-09-2011 08:37 PM
if using a lathe as Gary stated, what about having a large cylinder that you bring down to the diameter you want on the lathe. After it is the desired diameter cut it into a lot of slices of desired thickness on the bandsaw.
View zindel's profile
257 posts in 2580 days
#9 posted 05-09-2011 10:18 PM
How big? you could use a Hole saw? just take out the drill bit in the middle…cut it off so it doesn’t hit the wood? I think they make these for drill presses. But depends on the size you need there is a limit to how big they make them.
-- If you can't fix it with a hammer, You've got an electrical problem.
#10 posted 05-10-2011 01:39 AM
If I had to make that many, I would carefully make a template on the scrollsaw (or bandsaw with the circle cutting jig if you prefer. Cut the rest of them oversize, stick them to the template with two sided tape and finish them up with a good flush trim router bit (some call it a template bit). All of them would be perfectly the same from using the template.
#11 posted 05-11-2011 08:54 PM
sorry for late reply…. thanks guys lots of ideas and solutions. turning on lathe seems fast way but i don’t have lathe. i will try all other and see which one is fastest and easy to make bulk quantity
i was thinking for vacuum clamping with template routing. it also need investment in vacuum clamping setup.
Paul nice video and very versatile jig
View bubinga's profile
861 posts in 2597 days
#12 posted 05-12-2011 01:54 AM
You need to make a jig, to hold your square stock, with a template on top, flush with the top of the jig, to cut your inside recess, I made the template, from quarter-inch hardboard, you could make a more durable template from plastic, use a guide bushing in a router to cut the recess, use a mortising bit, a trim router works best. The jig is just a base and four sides. I did not sand the recess, because I put in Cork there.
The square stock and the template must fit the jig perfect, with no slop. (Drill a hole in the bottom of the jig, to push out the stock when you’re done. Put the jig in a vice, and you can reach under it to do this.)
You then make a tight fitting disk, from quarter-inch hardboard, to fit the recess, with a hole in the center for the pin, to be used with a circle cutting jig on the band saw.I ended up making two discs, before I got fit just right . My circle cutting jig was shop made, it uses a 3/16 tension pin, so when I drill a 3/16 hole it is a tight fit, And cuts perfect circles every time.
After I cut discs on the band saw, I made a V jig for the router table, to around over the edges,(take light cuts here)
I made another expanding disk, with the carriage bolt through it, to expand into the recess, and mounted in the drill press, for sanding the edges. You could do the sanding, on a lathe also, I did not have one at the time.
If I can figure out where I put the Jigs, I will take pictures and show you.
As long as you cut the initial square stock the same exact size, every time, you can make these all day, accurately
Is this clear to you what I’m saying ?
-- E J ------- Always Keep a Firm Grip on Your Tool
View Steve2's profile
75 posts in 3501 days
#13 posted 05-13-2011 10:25 AM
Use a circle pattern – not to be confused with a jig – laid over the top of the material, all clamped down, and run the router baseplate bushing inside the pattern. No pins, no holes. Rockler carries them, made of 1/4” acrylic with full range of diameters – or simply make your own initial pattern with the pin guide for the pattern.
-- Regards, Steve2
View David Grimes's profile
David Grimes
2078 posts in 2569 days
#14 posted 05-13-2011 12:28 PM
Securely clamp blanks to drill press table, then use this WITHOUT the center pilot…
Rockler has it for 9.99
-- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia
View Yupa4242's profile
116 posts in 2531 days
#15 posted 05-14-2011 03:08 AM
I dunno if it was me and I was gonna need hundreds i would make a jig out of hardboard with circles cut out like a honey comb. Then i would place it over a full sheet of wood and use a pattern bit and router. But to really make those coasters shine I would get a CNC Router to etch out all the circles before cutting em out. Too bad this method is way too costly. Lots of good Idea for me to try from the poster above on a rainy weekend :)
-- "If the Universe is Infinite, Then all dreams are real."
