Help on electrolysis
Forum topic by bigike posted 745 days ago 907 views 0 times favorited 5 replies Add to Favorites Watch
View bigike's profile
bigike
4023 posts in 1458 days
745 days ago
Topic tags/keywords: plane rehab electrolysis rust removal
I did everything what the blogs told me to do but my charger reads “faut” when I try to put it to 6 amps what am I doing wrong?
5 replies so far
View WayneC's profile
WayneC
9596 posts in 2267 days
#1 posted 745 days ago
bump – someone should have expertise on this.
View fredf's profile
fredf
495 posts in 1880 days
#2 posted 745 days ago
Perhaps your charger is too smart???? I bet that a simple one will work better. it has figured out that something is wrong with your “battery”
-- Fred, Springfield, Ma
View Nomad62's profile
Nomad62
567 posts in 1128 days
#3 posted 744 days ago
It could be that your charger is set up to more or less dump 6 amps thru a battery, which has a level of resistance to having electricity pushed into it; the charger could be actually able to dump 8-10 amps under a no-load situation, creating the fault condition. Perhaps a better quality charger would be in order to sustain that amperage.
View 000's profile
000
3352 posts in 786 days
#4 posted 744 days ago
I tried electrolysis and found that I really – really didn’t like it. Too much fuss and bother.
I tried citric Acid and found I really – really liked it.
All I need is a poly bucket and some water and citric acid.
That’s it. I don’t even use a measuring cup, I just dump it in the water.
I keep a poly bucket of the stuff around quite a lot. Lasts a long time de-rusts everything no pitting Also passivates SSTs very well and if you want to go the extra mile get some EDTA and toss that in to the solution.
Citric acid is un-demanding you don’t need to pay attention to the titration just dump some it in the water and toss the metal in. Time is not too important, temperature is not important make it as strong as you please.
It even sharpens old files. Can’t do that with the battery charger.
-- When the moderator chooses sides, his site sucks.
View cut3times's profile
cut3times
115 posts in 1176 days
#5 posted 744 days ago
See if this article helps.
-- And Still Too Short - "Life is what happens to you while you're busy making other plans." John Lennon
