Judson Beaumont chest/dresser design
Forum topic by Sawtooth posted 05-08-2011 07:03 PM 1743 views 0 times favorited 5 replies Add to Favorites Watch
View Sawtooth's profile
Sawtooth
116 posts in 3553 days
05-08-2011 07:03 PM
Topic tags/keywords: question
I was looking at some of Judson Beaumont’s work and was wondering how he builds these;
http://www.straightlinedesigns.com/sobey.html
http://www.straightlinedesigns.com/cindy.html
Does anyone have any ideas about the construction of these? It looks to me that he may use a bent lamination form for the sides then cuts the front and back using a template including drawer openings on sheet of plywood or mdf. Then attaches them somehow. After that he uses nicer veneer to match it all up and cover the whole thing.
Any ideas??? I’d like to try it and would do it the way I described above. But if there is a “right” way It would make it a lot easier.
Thanks
-- "I'm a lumbrjock and I'm OK..."
5 replies so far
View HerbC's profile
HerbC
1792 posts in 3098 days
#1 posted 05-08-2011 07:15 PM
You might want to talk to Brent, He’s done a couple of simular projects…
Look Here
Good Luck!
Be Careful!
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
View Loren's profile
10477 posts in 3887 days
#2 posted 05-08-2011 07:52 PM
Vacuum veneering. You build a form for the panels and laminate
them up. Then you’d put front, back and sides of the cabinet
together and veneer and trim each side one at a time by putting
it back in the bag or using some variant of hammer veneering.
Organize your process about making a veneerable 3-dimensional
substrate in the shape you want first.
View jack1's profile
jack1
2117 posts in 4266 days
#3 posted 05-08-2011 07:59 PM
I’ve seen plans for them on one of the sites that sells them. THey look neat.
Sawtooth
#4 posted 05-08-2011 09:18 PM
Thanks
13641 posts in 3580 days
#5 posted 05-08-2011 10:17 PM
bending the sides might be to muck work
for steam and forms
but saw kerfing alternately back and forth
would give you the ply-ability
and fill with epoxy to keep them there on a form
sand and veneer as stated
or some thinner layers ov ply laminated together
over a form
