Match this antique finish
Forum topic by Steve posted 03-27-2018 03:27 PM 488 views 0 times favorited 6 replies Add to Favorites Watch
View Steve's profile
Steve
76 posts in 1252 days
03-27-2018 03:27 PM
Topic tags/keywords: question oak finishing
A few months back, I turned three replacement finials for a friend’s antique chairs. I’m no expert in chairs, but these appear to be factory made, and probably not more than 100 years old. I turned the new finials from oak, which I believe is the type of lumber used for the chair.
I’m wondering if anyone has advice on how to match the patina and finish of the chairs to the new finials. I’ve been trying to think of a solution since I made these, but have come up completely blank.
~Steve
-- ~Steve
View WyattCo's profile
WyattCo
93 posts in 346 days
#1 posted 03-27-2018 04:38 PM
Match the light brown stain the best you can and let it cure. With a match for the dark stain, wipe it on, let it set for just a few minutes. Then wipe off the dark stain in the areas you want the light color to be seen. Test on scrap. Mineral spirits is your friend. It’s going to be easier than you think.
View John Smith's profile
John Smith
1555 posts in 404 days
#2 posted 03-27-2018 05:43 PM
once you match the color, texture and patina on a scrap of the same material,
put it out in the sun for a day or two to see if the wood darkens which will
darken the piece and maybe cause a darker tint that does not match the rest of the chair.
(mahogany is notorious for this).
nice work on the finials, BTW !!!
-- I started out with nothing in life ~ and still have most of it left.
View bondogaposis's profile
bondogaposis
5157 posts in 2593 days
#3 posted 03-27-2018 06:21 PM
I would use red mahogany water or alcohol base dye, topped with BLO then use Behlens Van Dyke brown shading and glazing stain, top coat with varnish of your choice. It will take some experimentation. Antique finishes are very hard to match.
-- Bondo Gaposis
View OSU55's profile
OSU55
2035 posts in 2231 days
#4 posted 03-27-2018 06:57 PM
Match the lighter color, stain or dye, wont matter much because not much will show. Two ways to do the dark,probably dark walnut and possibly some black. Could use a glaze and only wipe off the hi areas, or tint shellac and spray the dark where needed, airbrush style. I would probably spray the shellac. Top with probably lacquer but hard to tell from pic.
View AxkMan's profile
AxkMan
65 posts in 368 days
#5 posted 03-28-2018 01:49 AM
Looks like a dark walnut or even ebony. You can apply a light tone coat (like pine) as the base and then use the darker. This lessens the effect of the darkening allowing several layers to be applied without reaching true black.
Steve
#6 posted 03-28-2018 03:29 PM
Thanks, everyone, for the tips. I’ll do some experimenting and let you all know how it goes.
~Steve
-- ~Steve
