Painting plywood - edge finishing
Forum topic by wwbob posted 05-08-2011 07:13 AM 6720 views 0 times favorited 12 replies Add to Favorites Watch
View wwbob's profile
wwbob
111 posts in 2783 days
05-08-2011 07:13 AM
Topic tags/keywords: finishing question plywood edge finishing
My next project is a simple plywood stool that will be painted. I would like to do a little something to the edge so the layers of the ply aren’t super visible . I do not want to add the glue on edging nor a hard wood.
Solutions I have found are: wood putty, and elastomeric paint.
Other suggestions?
-- "I like the quiet I hear." - Channing, age 4
12 replies so far
View bubinga's profile
bubinga
861 posts in 2576 days
#1 posted 05-08-2011 07:32 AM
Depending on the type of ply you are using , use wood glue and thin it a little, ,or mix the glue with fine saw dust ,and thin it a little more, sand smooth when dry
Don’t use to much, just fill the pores
Try it on some scrap first
-- E J ------- Always Keep a Firm Grip on Your Tool
View devann's profile
devann
2246 posts in 2600 days
#2 posted 05-08-2011 07:42 AM
Have a look this LJs project. He explains an esay way to finish the edge of plwood. http://lumberjocks.com/projects/47550
The only other option I can think of is a slot cutter and the T type edging. I’d try the elastomeric paint.
wwbob
#3 posted 05-08-2011 08:08 AM
E J, thanks, I had forgotten about wood flour and glue. Application method? small Popsicle stick? brush?
Darrell, that’s the project that suggested the elastomeric paint. I don’t have any of this paint and it’s pretty pricey for a small project. Lowe’s has some in a spray can, instead of $25+ for a gallon. might try that. Thanks.
13594 posts in 3249 days
#4 posted 05-08-2011 08:34 AM
i’ve used bondo
and sheet rock mud too
filling the pores
and sanding
till it is smooth
then paint
View Jamie Speirs's profile
Jamie Speirs
4167 posts in 2765 days
#5 posted 05-08-2011 09:13 AM
I’m lazy I use veneer.
jamie
-- Who is the happiest of men? He who values the merits of others, and in their pleasure takes joy, even as though 'twere his own. --Johann Wolfgang von Goethe
View UncleFester's profile
UncleFester
33 posts in 4095 days
#6 posted 05-08-2011 03:31 PM
Like Jamie says, I would use iron on veneer edge banding.
-- Uncle Fester
View allmyfingers's profile
allmyfingers
40 posts in 2554 days
#7 posted 05-08-2011 09:34 PM
iron on edge banding for interior work. thin cut hardwood glued and pinned for rough work and exterior.
-- I cut it 3 times and it was still too short?!?
View SteveMI's profile
SteveMI
1079 posts in 3202 days
#8 posted 05-09-2011 01:38 AM
Sheet Rock mud, like Patron said or glue sizing (wall paper). I’ve used both where the edges were rounded over and edge banding wasn’t practical. They both are some work and sanding.
Steve.
View Sorethumbs's profile
Sorethumbs
38 posts in 2555 days
#9 posted 05-09-2011 06:51 PM
I’ve used lightweight spackelding compound for the filler and sanded for painted stuff. It worked pretty good, but I usually use iron-on veener edge banding.
View jpc's profile
jpc
139 posts in 3089 days
#10 posted 05-09-2011 07:45 PM
i remember another L.J doing a kids bunkbed where he used epoxy something or other for the edges, let me peek around ill find the project, but his edges looked great
View dbhost's profile
dbhost
5686 posts in 3140 days
#11 posted 05-09-2011 08:03 PM
What bubinga said… Wood glue dilluted and fine saw dust to fill the pores. Of course you could use wood putty to fill the pores as well…
-- My workshop blog can be found at http://daves-workshop.blogspot.com, YouTube Channel https://www.youtube.com/channel/UCoa-AgyeFWqnQfGIJwdzkog
View Tedstor's profile
Tedstor
1643 posts in 2541 days
#12 posted 05-09-2011 08:58 PM
Would anyone happen to know if grain filler would work? I have a similar project in the works using 3/4” maple/birch.
