| Forum topic by Dick, & Barb Cain | posted 471 days ago | 745 views | 0 times favorited | 16 replies | ![]() |
471 days ago |
The only thing that I didn’t care for on my Rikon, was the way the light wouldn’t stay in one position. The way it was mounted, the thing would keep sagging down. The weight of the fixture would cause the threads to loosen all the time. This could end up being an safety hazard. I changed it today, you can see by the picture. I fastened an outlet box to the saw frame. I drilled the proper sized hole in the outlet knock outs, because the goose neck, & wire connection are smaller. Then I soldered them so they’d stay put. Now it stays right were I put it. It even reaches farther toward the in feed side, for better light on the work. -- -** You are never to old to set another goal or to dream a new dream ****************** Dick, & Barb Cain, Hibbing, MN. http://www.woodcarvingillustrated.com/gallery/member.php?uid=3627&protype=1 |
