Adapter for lathe
Forum topic by rmoore posted 05-07-2011 09:04 PM 1278 views 0 times favorited 10 replies Add to Favorites Watch
View rmoore's profile
rmoore
325 posts in 2755 days
05-07-2011 09:04 PM
Topic tags/keywords: lathe adapter pen turning
I have an antique lathe I’m setting up and would like to try pen turning on it. However, it was made in London and doesn’t have standard American threads on the headstock shaft. I got a quote from a local metal shop to make an adapter, $65.
After some brainstorming I thought of mounting a piece of UHMW to the face plate and turning a stud on it that could then be threaded to fit a mandrel. I have never worked with UHMW so I don’t know if it would be strong enough.
Anyone know if this would work or any other ideas, please let me know.
-- The more I learn, the more I realize I don't know. Ron, Crossville Tn
10 replies so far
View WayneC's profile
WayneC
13773 posts in 4218 days
#1 posted 05-07-2011 09:07 PM
Can you post a photo of the headstock?
View poopiekat's profile
poopiekat
4371 posts in 3855 days
#2 posted 05-07-2011 09:16 PM
Why not just bring your old headstock to that machinist, and ask him to make a new shaft, with 3/4”X16 standard threads on one end. Then, the sky’s the limit for accessories you can buy.
rmoore
#3 posted 05-07-2011 09:21 PM
Here is a picture of the headstock.
The face plate and the rest of the parts.
rmoore
#4 posted 05-07-2011 09:24 PM
poopiekat, The lathe has been passed down from my dad and grandfather. It is around 180 years old. I would like to keep it as original as possible.
View Minorhero's profile
Minorhero
373 posts in 2725 days
#5 posted 05-08-2011 05:24 AM
It is going to be hard to beat a price of 65 dollars for a custom adapter. In the picture I can not quite figure out what is stuck on the current headstock. Is that some kind of drive center? Does the headstock have a hollow cut to a morse taper? If so you could make pens just by buying a morse taper jacobs chuck.
rmoore
#6 posted 05-08-2011 03:14 PM
Minorhero, Yes, that is a drive center. The shaft is solid and threaded 9 teeth per inch. I think I may ask the metal shop about making an adapter with a threaded shaft on a flat base that I can screw to the face plate.
Minorhero
#7 posted 05-08-2011 09:54 PM
There looks to be a rod stuck into the outboard side. Just remember to remove that before powering up the lathe the first time. The rod looks like it might be rusted in place, but it seems unlikely to me that the rod is actually fixed in place so that it can not be removed. You might want to talk to the folks at owwm.org for information on restoring the lathe. This kind of thing is pretty much their bread and butter.
rmoore
#8 posted 05-09-2011 04:58 AM
Minorhero, If you are referring to the rod I’m thinking of, it is a lock for the shaft. It is loose and the shaft can be turned in further to make more room. I am in the process of repainting the parts and building a bed and legs for it to mount on. Hope to be done with it soon. I will post it as a project when it’s done. I went to OWMM.org but didn’t find anything listed for Holtzappfel, the maker of my lathe.
WayneC
#9 posted 05-09-2011 05:47 AM
Your manufacture is well known. You may want to check out google books….
http://www.google.com/search?q=Holtzappfel&tbm=bks&tbo=1
rmoore
#10 posted 05-10-2011 12:40 AM
WayneC, Thanks for the link.
