compressor for woodworking duties and sandblasting
Forum topic by martin007 posted 620 days ago 1225 views 0 times favorited 11 replies Add to Favorites Watch
View martin007's profile
martin007
110 posts in 675 days
620 days ago
HI All
I would like to purchase an air compressor for woodworking duties like finishing and sandblasting. Any recommendation on size, model, power etc…
thanks
-- Martin, Gatineau, Québec
View matter's profile
matter
209 posts in 669 days
620 days ago
I have a 2 stage, 10 gallon, twin cylinder craftsman that is older than I am. Works like a charm for regular shop duty. Nailers, small spraying jobs, buffing, etc.
If I was spraying a lot, I would go 25 gallons or more, plus a 120 psi tank pressure @ 3-5 CFM
-- The only easy wood project is a fire
View mrtrim's profile
mrtrim
1698 posts in 780 days
620 days ago
sandblasting takes a huge amount of air i have a 6 hp 60 gal. porter cable ive had about 6 years . it has done a good job . id check at the box stores for a 5 or 6 hp 60 gal.
View rikkor's profile
rikkor
11335 posts in 774 days
619 days ago
Get the biggest one you can afford. Especially for spraying and sandblasting.
View Thos. Angle's profile
Thos. Angle
4013 posts in 862 days
619 days ago
I agree with Rikkor on size. Seems I listen to mine a lot more than I should.
-- Thos. Angle
View Catspaw's profile
Catspaw
186 posts in 715 days
619 days ago
We went thru the a/c thing not too long ago. The compressor guys will tell you those really great prices on the big box a/c are from china and are crap. Apparently there’s an a/c duty motor and the big box ones don’t have that….just what I heard.
If you’re going to sandblast, I would suggest making sure you get one with the higher air pressure. Like about 155 or so. anything less won’t blast very well. o.k. it will for wood more or less (not on rusty metal though)...but, you wouldn’t figure out right away that with two tanks, same size, one at 110 psi and one at 155 psi…the one with 155 psi won’t run as much as the other if you’re using them both at the same pressure.
-- arborial reconfiguration specialist
View Al Killian's profile
Al Killian
271 posts in 653 days
617 days ago
i WOULD TRY TO FIND A 40 gallon tank w/ atleast 5 cfm.
teenagewoodworker
2482 posts in 668 days
617 days ago
i agree with everyone. for sandblasting and spraying get the biggest you can get.
View Dadoo's profile
Dadoo
1723 posts in 890 days
617 days ago
Mine’s a 30 gallon and is suitable for all except sandblasting. You need a lot of air for that. The only real problem with mine (like so many others) is the noise.
What? About 3:30 I think! Huh? Wha?
View Suz's profile
Suz
51 posts in 656 days
617 days ago
Unless you get one of those ‘toy sand blasters’ you will need a compressor that will have about 10 or 11 CFM at 90 to a 100 lbs.
Check out the sandblaster you want to use first and see what the requirements are.
The same goes for air tools like a air sander.
-- Jim
martin007
617 days ago
Well, thanks all for the tips
I got a single stage, oil lubricated, 26 gallon, campbell Hausfeld, VT6271 model, 3.3 running HP, rated at 10.3cfm @ 90 psi, I couldn’t afford more than that, hope I will be satisfied.
Any of you out there do sanblasting for stripping paint from old furniture? (without wood damage) .Any article on the subject?
Al Killian
615 days ago
I have not done this, however I have heard of it. You need the fine stuff or even backing soda.
