Bandsaw box
Forum topic by gul posted 05-07-2011 05:38 PM 1461 views 0 times favorited 5 replies Add to Favorites Watch
View gul's profile
gul
400 posts in 2989 days
05-07-2011 05:38 PM
Topic tags/keywords: blade
Hi, I managed to get 1/8’ and 3/16’ bandsaw blades!(Finally)
Please advise which one to use to make a bandsaw box like steve’s.Also advise what height the box should be.I tried 1/8 on 5’ height but it’s not cutting right.
Thanks.
Regards.
5 replies so far
View 58j35bonanza's profile
58j35bonanza
395 posts in 2719 days
#1 posted 05-07-2011 06:30 PM
I like to use 1/8” blades.
After I put a new blade on I use a diamond stone to round the back of the blade slightly.
Doing this, you will be able to turn corners a little tighter and it also smooths out the weld so you get a better cut.
-- Chuck
View Gene Howe's profile
Gene Howe
10542 posts in 3455 days
#2 posted 05-07-2011 06:54 PM
Gul, I wouldn’t try a 1/8th in 5” of hardwood. A 1/8th is pretty much maxed out in a 2” thick piece. A 3/16th is about as small as I would go. But, all my 3/16th blades are 10 tpi rakers , so I usually opt for the 1/4 with 6 tpi.
Correct tension and slow and easy should produce a good cut.
For my larger (6”thick) boxes, I use a 3/8th 4 tpi, 6.5 hook angle with alternate set by Timber wolf from Suffolk Machinery.
Actually, almost all my blades are Timber wolf.
Here’s a chart for you. Blade Selection Chart
View DonH's profile
DonH
495 posts in 2844 days
#3 posted 05-07-2011 07:40 PM
Hi Gul
Gene has provided great information and the blade selection chart is the best reference. Light blades bow and twist a lot when cutting thick stock. Looking forward to seeing your posts on bandsawn boxes! By the way, what kind of band saw do you have?
All the best
Don
-- DonH Orleans Ontario
View gul's profile
gul
#4 posted 05-08-2011 05:02 PM
Thank you all.I guess i have the wrong blades :(....waited so long for them,oh well.
View DonH's profile
DonH
#5 posted 05-08-2011 07:39 PM
Hi Gull – dont give up on the blades – see my email response re setting up the band saw.
Don
