How to chamfer close to an inside edge?
Forum topic by ScoFF posted 05-07-2011 02:54 AM 4565 views 0 times favorited 6 replies Add to Favorites Watch
View ScoFF's profile
ScoFF
21 posts in 3530 days
05-07-2011 02:54 AM
I’m building a fairly large outer frame for a painting like I’ve done a few times in the past. I usually just go for the plain straight edges and sides but have a slight chamfer on the inside edge and set the painting inside. Normally I take the single long piece, put the chamfer on the edge using a router and then mitre the piece to make the 4 sides.
The problem this time is I forgot about the mitre and glued the frame together.
Now I have to chamfer the inside edge all glued up. What’s the best way to do this? If I use a block plane I’d come about 5 inches away from each corner before the front hits the corner. Then I’d use a chisle and try and finish it up? Is there a better way or tool that will come closer to the inside corner?
-- ...I will not be limited.
View cabmaker's profile
cabmaker
1730 posts in 2807 days
#1 posted 05-07-2011 03:43 AM
5 inches ? Are you sure thats a block plane ? Anyway your on the right track. Plane as far as you can then use scraper, rasp or like type tool. This is where a bullnose and or a chisel plane really earns its keep. You wont have any trouble doing this just keep it simple..Good luck
View BTKS's profile
BTKS
1986 posts in 3463 days
#2 posted 05-08-2011 11:21 PM
You can run the router chamfer bit right along the edge and into the corners. It will leave a rounded corner but you can finish that tiny cut with chisels. It will be easier to keep a consistent chamfer this way instead of trying to keep 3 to 5 inches even with the rest of the cut. I assume you have a bottom bearing guide and not a solid guide stem.
Good luck
-- "Man's ingenuity has outrun his intelligence" (Joseph Wood Krutch)
View Sorethumbs's profile
Sorethumbs
38 posts in 2646 days
#3 posted 05-09-2011 06:14 PM
Consider a rounded inner edge on this project. grab a round-over bit and route it. done.
View Bertha's profile
Bertha
13528 posts in 2691 days
#4 posted 05-11-2011 12:04 AM
+2 on chisel plane, carriage, or bullnose. Of those options, I’d vote chisel but break out the wallet. How big of a chamfer are you looking to make? You might be able to fashion a beading tool of sorts or just work it out old school with a chisel or scraper. Either way, it sounds like a good excuse to buy something!
10393 posts in 3646 days
#5 posted 05-11-2011 12:12 AM
Usually I’ve use a laminate trimmer with a chamfer bit for the straight
parts and do the corners with a very sharp pair of skew chisels. Cranked
skews will make it even simpler, but I don’t have those and find the
regular skews work pretty well if I am careful and they are sharp.
I do actually flip the skew chisel over and use the bevel side as well in
making these types of inside chamfered corners.
Skewed paring chisels, not the lathe kind.
You can do it with a regular 1” or wider chisel too, The extra width
help you slide the edge into the cut to sheer the wood.
View Steve2's profile
Steve2
75 posts in 3569 days
#6 posted 05-15-2011 03:36 PM
Just use a chamfer bit Rob. :)
-- Regards, Steve2
