Fallen Trees - Is GRAY ok?
« back to Coffee Lounge forum
Forum topic by MRod posted 163 days ago 177 views 0 times favorited 8 replies Add to Favorites
View MRod's profile
MRod
36 posts in 505 days
163 days ago
Hi folks,
Happy Wednesday!
I see a lot of downed trees in open land. They are gray in color, obviously left for a long time, or dead standing and finally fell down.
Question = is this wood usable for run of the mill woodworking projects?
Question #2 = If I took a chain saw to this wood, would I most of the time find the same gray dead dry look throughout?
Thanks,
MRod
-- MRod, Henderson, Colorado by way of Brooklyn!
teenagewoodworker
1932 posts in 211 days
163 days ago
you probably won’t find the same wood on the inside unless its really old. but just check for rot first becuase if it rotted its probably no good.
View coronet1967's profile
coronet1967
24 posts in 393 days
163 days ago
it is according to the tree pine and poplar have a very short shelf life when they are on the ground, oak, walnut, cherry will last a while longer but pretty much if they have been down for more than 2 years they have deteriated beyond use.
a good test is to sink your chainsaw into them if it cuts easy you may have a bad log. check the end of the log with a hatchet you can tell of it is good wood by how far the bit sinks into the wood
jay angel
-- "not all those who wander are lost" JRR tolken
View ww_kayak's profile
ww_kayak
69 posts in 167 days
163 days ago
But if it’s only “kinda” rotted, you may also find some good spalting :)
-- Tom, Central New York
View Daren Nelson's profile
Daren Nelson
310 posts in 348 days
162 days ago
This log laid in the mud for 5+ years. The bark was rotted off and what wood I could see was “gray”...kinda shined up on the mill ;)
-- Urban logger, http://nelsonwoodworks.biz/
View GaryK's profile
GaryK
8401 posts in 431 days
162 days ago
I’d open it up the see what I had.
View rikkor's profile
rikkor
7112 posts in 317 days
162 days ago
I think Jay’s idea about the hatchet would be the quickest way to determine if there was anything solid inside.
-- Maplewood, MN
View Andy's profile
Andy
12 posts in 191 days
162 days ago
I would rip about 2 3” slap off with your power saw and see what you find. Some trees rot from the outside while others rot from the inside out depending on what kind of wood it is.
View MRod's profile
MRod
162 days ago
I like the idea to check it out through a few whacks with the hatchet the best. I’ll pick one up asap.
Thanks folks!
Bookmark And Share This Page
