Pick one sized paring chisel
« back to Hand Tools forum
Forum topic by JADobson posted 03-22-2018 04:41 PM 478 views 0 times favorited 8 replies Add to Favorites Watch
View JADobson's profile
JADobson
1166 posts in 2232 days
03-22-2018 04:41 PM
Topic tags/keywords: paring chisel chisel
Want to add a paring chisel to my chest but only one. I don’t like having too many chisels. Too many edges to keep sharp. Which size do you find most helpful?
-- No craft is very far from the line beyond which is magic. -- Lord Dunsany — Instagram @grailwoodworks
8 replies so far
View Ron Aylor's profile
Ron Aylor
2649 posts in 768 days
#1 posted 03-22-2018 04:43 PM
I think I use 1/2” most often … after that 1-1/2”. It seems like I sharpen these two the most. LOL!
View Loren's profile
10477 posts in 3768 days
#2 posted 03-22-2018 04:48 PM
I use wide chisels mostly. They can’t get in
tight spaces obviously but they can be skewed
for shearing cuts. I also chop up thin and
tiny wood shapes with a wide chisel. I like
the balance with more weight at the cutting
end and I hold the chisel by the blade sometimes
and the width is easier to get a grip on and
keep it straight.
If you’re talking about the really long paring
chisels you probably don’t need them. Some
have thin, slightly flexible blades and some are
thicker. I have some Buck bros. crank neck
chisels which I use occasionally.
JADobson
#3 posted 03-22-2018 04:48 PM
Thanks Ron, 1/2” is what I suspected would be the most used size.
View JayT's profile
JayT
5824 posts in 2332 days
#4 posted 03-22-2018 04:50 PM
For paring, my most reached for is a vintage 7/8in Swan. Anything in the 3/4-1in range would work, I just like the feel of that one and the steel is marvelous. I also use a 3/8 a lot to get into smaller areas.
View bbasiaga's profile
bbasiaga
1240 posts in 2116 days
#5 posted 03-22-2018 04:53 PM
I went with 3/4” for the one I made.
Brian
View CharlieK's profile
CharlieK
556 posts in 3914 days
#6 posted 03-22-2018 04:58 PM
If I had to pick only one then I would probably choose 1/2”, maybe a 3/8, but probably 1/2”.
-- Adjustable Height Workbench Plans http://www.Jack-Bench.com
View John Smith's profile
John Smith
1313 posts in 283 days
#7 posted 03-22-2018 05:02 PM
I found it – never mind
-- some people are like a Slinky - - - pretty much good for nothing. But still make you smile when you push them down a flight of stairs.
JADobson
#8 posted 03-22-2018 05:51 PM
Thanks for the replies everyone.
