PM 66 sounds noisier than normal
Forum topic by eflanders posted 03-21-2018 10:32 PM 618 views 0 times favorited 13 replies Add to Favorites Watch
View eflanders's profile
eflanders
320 posts in 2084 days
03-21-2018 10:32 PM
Topic tags/keywords: repair rebuild tablesaw powermatic pm66 question
I could use some help from folks that are familiar with the PM 66 tablesaw. I bought the used several years ago and I really like it except for one thing, they’re noisy compared to other premium cabinet saws. It now seems like it is even noisier than when I got it. The saw uses two drive belts (3hp motor). That leads me to my questions: #1). How do you adjust the belt tension equally between the two belts? #2). Would you replace the belts given the age of the saw? #3). I’ve heard that the link belts are quieter and better. Are they appropriate in a dual belt setup like this?
Once I get the belts off I plan to take a good look at all of the bearings. Right now the arbor does not seek to have any excess movement but without drive belt tension, I should be able to judge their worthiness. I could really use all of your advice and experience in making things better here.
Eric
13 replies so far
MrUnix
7101 posts in 2433 days
#1 posted 03-21-2018 11:18 PM
1 – You don’t [1]
2 – Only if needed
3 – no
[1] You adjust tension so neither belt flops/vibrates. Easiest way is while it’s running so you can see when they get to that sweet spot.
eflanders
#2 posted 03-21-2018 11:24 PM
Thanks Brad I was hoping you would respond!
View avsmusic1's profile (online now)
avsmusic1
300 posts in 919 days
#3 posted 03-21-2018 11:32 PM
Hmm I’ve never found the 66 to be notably noisier – I’ve never sought to make the comparison but it never struck me as noisier either
View CaptainKlutz's profile
CaptainKlutz
686 posts in 1728 days
#4 posted 03-21-2018 11:35 PM
Noise is either belts or bearings. On a older saw, usually both have been ignored and need to be replaced.
With belts removed, run the motor and rotate the arbor; checking for noise.
They should be perfectly quiet. If not, replace the bearings.
There are all kinds of internet how to’s and videos for PM66 restoration,
Some here on LJ if you search, but largest amount of information for old saw is OWWM site.
View JBrow's profile
JBrow
1366 posts in 1154 days
#5 posted 03-22-2018 03:44 AM
eflanders,
Not sure if you have the manual for the PM 66. If not then…
http://www.lexington.woodworkersguild.org/shop/manuals/Powermatic%20Model%2066%20Table%20Saw%20Manual.pdf
View AlaskaGuy's profile
AlaskaGuy
4981 posts in 2543 days
#6 posted 03-22-2018 04:37 AM
I always do every thing wrong. I have an old 1940’s Delta Rockwell 12-14 cabinet saw with a 4 pulley system. Like a dummy I put link belts on it 10 to 12 years ago. Maybe even longer. I don’t know now if its quieter or not but I can’t see where it’s done any harm. I do think it help a bit with vibration.
eflanders
#7 posted 03-22-2018 12:29 PM
Thanks folks!
Avsmusic1 At the schools I worked at the saws used there were all whisper quiet.
View TheFridge's profile
TheFridge
10814 posts in 1720 days
#8 posted 03-22-2018 12:48 PM
Changing belts and bearings is the next thing I do to a piece of used equipment after cleaning.
View coxhaus's profile
coxhaus
93 posts in 1129 days
#9 posted 03-27-2018 08:27 AM
I had a Freud combo blade which was real noisy. I now run a Freud Cabinet’s makers saw blade and a 24T saw blade. I am much happier as they are more quiet.
eflanders
#10 posted 03-27-2018 03:56 PM
Today I took the belts off to start the troubleshooting process. Ran the motor without belts. It ran nice and smooth and as quiet you’d expect from a 3 horse motor. Checked bearings on the arbor, they ran smooth without any excess play. I closely examined the belts and they too were in great shape. Then I noticed that the arbor drive pulley had some play to it. BINGO! I removed it from the shaft way too easily! It turns out that the set screw had loosened up. I removed it, examined the key and keyway for damage and fortunately there was none. Whew! So I removed the set screw, chased the threads, reinstalled, tightened securely, reinstalled the belts to proper tension and let her rip. She ran as smooth as a baby’s bottom by golly and the quietest I’ve ever heard! I’m one happy camper folks that this was all it was!!!
Thanks to all for your advice, suggestions, etc.!
View maxhall's profile
maxhall
80 posts in 2435 days
#11 posted 03-27-2018 04:17 PM
I install blue loctite to set screws so that doesn’t happen to me. I’ve had a few automotive issues that taught me that lesson.
eflanders
#12 posted 03-27-2018 10:34 PM
Maxhall, I considered adding a drop of it and even had the bottle there at the ready, but I decided against it due to the very limited access to the set screw with the table top still on. I did torque the screw down and if by chance it does loosen up again, I’ll definitely put it on then.
AlaskaGuy
#13 posted 03-28-2018 05:06 PM
Contact Us
Purple Loctite Threadlocker, Low Strength, Easy Removal
> Henkel Adhesives North America > Industrial > Adhesive Industrial > Threadlockers > Loctite Threadlocker Colors > Purple Threadlockers, Small Thread Low Strength
Back to Overview
Purple Threadlocker
Low Strength, Easily Removable Threadlocker for Small Threads
LOCTITE® 222™ Purple Threadlocker prevents loosening from shock or vibration, but also allows for simple, hand-tool disassembly without shearing the screw.
