What paint + top coat should I use for built-in cabinet/shelving unit?
Forum topic by Creations316 posted 03-21-2018 06:37 PM 593 views 0 times favorited 5 replies Add to Favorites Watch
View Creations316's profile
Creations316
1 post in 307 days
03-21-2018 06:37 PM
I have done a handful of projects that I painted, but I just used paint I had on hand (paint meant for walls). I was never happy with the way they turned out. I am working on finishing a commission job for a custom built-in cabinet/shelving unit, and the client wants it painted white. I have been doing some research, but I haven’t found exactly what I am looking for. Does anybody have any personal experience with a specific paint brand? What about a top coat? The cabinet face frame and doors are made with poplar, and the rest is made with birch plywood.
5 replies so far
View Ripper70's profile
Ripper70
1196 posts in 1149 days
#1 posted 03-21-2018 06:42 PM
Worth investigating:
Sherwin Williams ProClassic Interior Waterbased Acrylic-Alkyd
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
View John Smith's profile
John Smith
1554 posts in 403 days
#2 posted 03-21-2018 07:21 PM
photos of your issues and concerns will help us help you.
I have had good results with Valspar, Ben Moore and Sherwin Williams.
personally, I like a good Waterbased Acrylic-Alkyd enamel for things
that get a lot of use – like doors, casework, cabinets, etc. just as Ripper suggested.
keep in mind that the home owner will more than likely clean often
and use the wrong cleaning agents that could very well damage the paint
that you applied. (think out of the box).
high traffic areas demand a high traffic resistant finish.
starting with a penetrating stain blocker sealer is the first step.
paints are designed for specific applications: as you said, wall paint is for walls.
trim paint is more durable and holds up well to high traffic situations.
Jbay, a valued member here just finished a remarkable furniture piece that is all white
and it will be interesting to see his finished project with the painting summary.
a forum that I visit a lot is http://www.painttalk.com/ – - – you may get some good info there also.
-- I started out with nothing in life ~ and still have most of it left.
View hkmiller's profile
hkmiller
117 posts in 322 days
#3 posted 03-21-2018 07:40 PM
If you have a sprayer, you can go with White catalyzed lacquer.
This is a great product:
http://www.lenmar-coatings.com/product-detail/pro/lenmar/ultra-unilaqcab-acrylic-white-topcoat
-- always something
hkmiller
#4 posted 03-21-2018 07:43 PM
If you have a sprayer, you can go with White lacquer.
-- always something
View John_H's profile
John_H
190 posts in 1946 days
#5 posted 03-22-2018 03:10 AM
Take a look at General Finishes. They have a pigmented poly in black or white in three different sheens – satin, semi-gloss or gloss. Very easy to work with. Usually dries in 2 hours, easy to sand and is formulated for spraying.
https://generalfinishes.com/wood-finishes-professional/water-based-paints-glazes-and-pigmented-top-coats/enduro-pigmented-white
