| Forum topic by Brett | posted 750 days ago | 901 views | 0 times favorited | 5 replies | ![]() |
750 days ago |
While out rust hunting, I saw a saw (I did, I did) with teeth of different lengths. In other words, the tooth length altered from long to short to long to short. It seems like the shorter teeth would never contact the wood. What’s the purpose of a tooth pattern like this? -- More tools, fewer machines. |
5 replies so far
#1 posted 749 days ago |
Nobody else wants to guess ?
OK, I’ll try. Next ? -- Glen, Vernon B.C. Canada |
#2 posted 729 days ago |
I seem to remember way back when the world was still black and white (at least that’s what I tell my kids) that felling saws had teeth of different lengths. I believe the shorter teeth weren’t really for cutting but for clearing the kerf of sawdust in the green wood. Perhaps the shorter teeth on this saw serve the same purpose. -- "Checking for square? what madness is this! The cabinet is square because I will it to be so!" Jeremy Greiner LJ Topic#20953 2011 Feb 2 |
#3 posted 728 days ago |
The cut is started using either the front or back end of the blade. Easier to start a kerf with shorter teeth, and then get aggressive with the longer ones in the main area of the blade used during a normal stroke. Not uncommon sharpening pattern for those who did a lot of ripping. Go -- Go http://ncwoodworker.net/pp/showgallery.php?cat=500&ppuser=730 |
#4 posted 728 days ago |
When I was learning to sharpen handsaws I actually created some saws with alternating long and short teeth. All teeth set one way are sharpened on the filing machine and then all the teeth set the opposite way are filed. If one isn’t watching he can file deeper and harder on one set of teeth than the other, thus creating one long and then one short tooth. As was said the long teeth do the cutting and since they are all set the same way it is difficult to cut a straight line. The goal in sharpening the teeth was to have all the same length. To test after filing a few teeth on the second set, I would stop the filer and lay a flat washer across the teeth. There was enough set that if the teeth were the same lenth the washer would balance. If one set of teeth were longer the washer would either not balance or would set at an angle. Maybe this may explain the saw you say you saw. -- Garry, Kentucky |
#5 posted 728 days ago |
Teeth become irregular with regular sharpening. If the saw-filer was lazy, Some saws have deeper gullets between some of the teeth, but with |
| Forum | Topics |
Woodworking Skill Share
8794 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
81 |
Finishing
1534 |
3552 |
15791 |
Hand Tools
2037 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6162 |
