Dewalt 735 Dust Port Clogging Issues
Forum topic by AM420 posted 03-20-2018 07:04 PM 249 views 0 times favorited 6 replies Add to Favorites Watch
View AM420's profile
AM420
68 posts in 346 days
03-20-2018 07:04 PM
I recently got a Dewalt 735 (as I believe many people have) and seem to be having issues with the dust port. It seems to get clogged every time I pass a piece of wood through it, both at the planer end and/or at the dust collector end. I don’t feel like I’m taking a ton off of the wood when I make a pass, Less than 1/16 according to the gauge.
I must be doing something wrong, otherwise I’m sure this would be a very common complaint.
View mpsprunger's profile
mpsprunger
22 posts in 1823 days
#1 posted 03-20-2018 07:14 PM
I ran some pine through mine, and it clogged, seemed the moisture content was high, I can’t remember exactly its been awhile. I ended up opening the unit and finding this area filled w/ chips
View msinc's profile
msinc
331 posts in 466 days
#2 posted 03-20-2018 07:42 PM
I have never had mine clog…the little motor and fan set up in this planer is pretty powerful. If I turn mine on without the dust collector hooked up and hold my hand in the way of the discharge it is very strong. If you turn yours on and it don’t seem to be blowing air very hard I would bet you have something blocking it. There is a thread on here that shows how to take it apart. Mine blows hard enough that I almost cannot hold my hand over the discharge port when it is on. Also, when I am planing a board the chips actually hurt when they hit my hand if I just let them blow out and stick my hand in the way. I cant imagine wood shavings of any kind not getting completely blasted out no matter how much moisture or what type of wood….gotta have an obstruction somewhere.
AM420
#3 posted 03-21-2018 11:56 AM
I’ll have to try it with the hose off and see how it feels. But it seems to me the chips just get caught up on the dust port attachment that came with the planer. It has some plastic pieces on the inside edge of the attachment, similar in configuration to crosshairs. I don’t know why they’re there, but suspect they are holding back the chips and causing clogging.
It also tends to clog at the collector end, but that could be due to the cheap HF collector I have. Both end get clogged.
View Jeff's profile
Jeff
428 posts in 3156 days
#4 posted 03-21-2018 12:11 PM
Could you post a picture of the outlet and crosshairs? It might give us a better idea of what’s happening and possible solutions.
View ChuckC's profile
ChuckC
828 posts in 2897 days
#5 posted 03-21-2018 12:38 PM
Take the top cover off as if you were changing the blades and see if anything is clogged inside. My 735 inflates the bag in my DC when the DC is turned off. The blower is very powerful.
View chrisirving's profile
chrisirving
97 posts in 393 days
#6 posted 03-21-2018 12:54 PM
The only time mine has clogged was from planing wet wood, like cedar.
