Finishing plywood
Forum topic by dpwalker posted 05-04-2011 02:21 AM 1227 views 0 times favorited 7 replies Add to Favorites Watch
View dpwalker's profile
dpwalker
273 posts in 2704 days
05-04-2011 02:21 AM
I have a small table top of birch plywood with a Zebra wood inlay. I have finished it with 3 coats of Arm-R-Seal gloss. The Zebra wood has a nice sheen to it but the birch PW is dull & lifeless. Can anyone tell me how to get a gloss on the ply? Thanks
-- You have not really lived until you do something for someone who can never repay you.
7 replies so far
View Steven H's profile
Steven H
1117 posts in 2933 days
#1 posted 05-04-2011 04:20 AM
I thought birch plywood is dull & lifeless wood.
Steven H
#2 posted 05-04-2011 04:24 AM
Without stripping the Gloss off, you can tint the Arm-R-Seal with UTC COLORS,(they come in small tubes, any paint store or home centers should have them) or any pigment stain. It will add color.
dpwalker
#3 posted 05-04-2011 06:14 AM
Steven H thanks for the suggestion. I really don’t want to tint the wood. I like the natural color. I am trying to get the birch to shine like the Zebra wood. It seems the wood is soaking up the finish & still has a satin look.
View fussy's profile
fussy
980 posts in 2923 days
#4 posted 05-04-2011 08:50 AM
Are you thinning the arm-r-seal? After 3 coats you should have a fantastic shine. I’ve never used Arm=R= Seal, so I don’t know what it’s like. I’m working to replace our steps with red oak. I put on 3 coats of Ace gloss polyurethane and the shine was so deep I had to knock it down with 0000 steel wool and wax to satisfy my wife. If I were you, at this point I would sand lightly and try brushing on a coat of almost any poly out there and see if that gives the gloss you’re after.
Steve
View Grandpa's profile
Grandpa
3259 posts in 2548 days
#5 posted 05-04-2011 04:26 PM
The pores have to fill until the poly can lay on the top. That gives the floss. It has to be sealed. You could seal it in several ways. I used to use sanding sealer but they claim it is too soft. I have used polyurethane thinned 50/50 with turpentine. One or two coats then straight poly over that. Close the pores is all I can say.
Steven H
#6 posted 05-04-2011 05:45 PM
I agree with grandpa.
Theres nothing you can do now, unless you you strip it off and start over.
Before applying any topcoats, use a squeegee and thin Arm R Seal with any naptha or any solvents. Force the varnish into deep pores. At the end, I will have a paint tray or any tray to catch the excess.
Let dry, then do it at least 3 times or more if need.
You can use also use water base products or buy Pore Fillers products.
dpwalker
#7 posted 05-05-2011 03:07 AM
Thank you all for the good advice. I put another coat of Arm-R-Seal on today & it is starting to take on a sheen. I really think a couple more coats & light sanding in between will do the trick.
I truly appreciate everyone’s help.
