Forgot to elongate holes for pins in breadboard end
« back to Joinery forum
Forum topic by Greenlaker posted 03-20-2018 04:22 PM 540 views 0 times favorited 7 replies Add to Favorites Watch
View Greenlaker's profile
Greenlaker
4 posts in 268 days
03-20-2018 04:22 PM
Topic tags/keywords: table breadboard expansion oak joining
Hi All,
I’m building a dining table.
48” wide
Quartersawn Oak (top is just under 1” thick)
Dry I think
Now in garage, temp 66, humidity 30
We’re in Wisconsin, kitchen summer probably around 75 degrees and 55 humidity?
Yesterday I attached one of the breadboard ends and forgot to elongate the dowel holes through the tenons. (I used 3/8” oak dowel pins, 5 of them). Also, my breadboard is non-standard. It is really a skirt and breadboard in one (so it is 1.25” horizontal x 5.25” high (thick if you will)). I can try to send/post pictures if needed—this is my first post so please forgive any errors/omissions/style faux pas I might be making.
It would be a lot of work to cut the breadboard end off and re-do, and, I’m already a couple inches shorter than wife wants table in the first place.
Am I crazy to leave it as is and “give it a try”?
Thanks so much, in advance, for any advice!
Greenlaker
7 replies so far
View splintergroup's profile
splintergroup
2429 posts in 1423 days
#1 posted 03-20-2018 04:42 PM
If you didn’t use any glue, you could try and drill out the dowels with a slightly undersized bit, disassemble, and elongate the holes where needed.
So the BB end spans 48”?
The shrinkulator shows about 3/8” of an inch expansion which probably would cause some cracking.
View JayT's profile
JayT
5960 posts in 2411 days
#2 posted 03-20-2018 04:47 PM
+1 for drilling out the dowels, if possible.
Quarter sawn will move less than flat sawn, but you would probably still run into problems on a top that wide.
View gargey's profile
gargey
1013 posts in 976 days
#3 posted 03-20-2018 05:03 PM
You’ll be fine as is if you’re OK with it exploding later on.
Greenlaker
4 posts in 268 days
#4 posted 03-20-2018 06:18 PM
Yes, span is about 48” (about 46” actually)
Unfortunately, I did glue the center 6” or so—so I don’t think drilling out the pins will help as I don’t think the BB will come off…..
If you didn t use any glue, you could try and drill out the dowels with a slightly undersized bit, disassemble, and elongate the holes where needed.
- splintergroup
- splintergroup
splintergroup
#5 posted 03-20-2018 06:30 PM
Ok, so it is attached. You can still drill out the dowels where there is no glue to relieve any stress from wood movement. If the center glue area keeps the BB end satisfactorally tight to the table top, replace the dowels with short stubs (that don’t touch the internal tenon) and call it a day.
If the BB end bows away, you can add long screws that penetrate the end grain of the tabletop. Drill a pilot hole the full depth, then wallow out the hole through the BB by drilling a hole to each side of the pilot hole (clean out with a narrow chisel). The head of the screw needs to be recesses into the BB by enough so you can hide the wallowed out hole with a square plug (all typical of Greene & Greene BB top construction).
Greenlaker
4 posts in 268 days
#6 posted 03-20-2018 06:33 PM
WOW, what a fantastic idea…...THANKS THANKS THANKS
Ok, so it is attached. You can still drill out the dowels where there is no glue to relieve any stress from wood movement. If the center glue area keeps the BB end satisfactorally tight to the table top, replace the dowels with short stubs (that don t touch the internal tenon) and call it a day.
- splintergroup
Greenlaker
4 posts in 268 days
#7 posted 03-20-2018 06:35 PM
Thanks to gargey and JayT too!
