Glue sqeeze out detection
Forum topic by Alongiron posted 777 days ago 973 views 0 times favorited 11 replies Add to Favorites Watch
View Alongiron's profile
Alongiron
336 posts in 890 days
777 days ago
We have finished gluing up a nice project, sanded the project and think that we have all the glue squeeze out removed. We put on a nice coat of stain and find out that we DID NOT get all the glue off of the project and it looks like crap!
I think that this has happened to all of us at some point.
My question is this: How do you check your work for glue residue prior to staining?
-- Measure twice and cut once.....
11 replies so far
View SergioC's profile
SergioC
82 posts in 864 days
#1 posted 777 days ago
I can usually see it when I wipe down with mineral spirits before finishing.
View DrDirt's profile
DrDirt
1719 posts in 1939 days
#2 posted 777 days ago
Same as Sergio – little mineral spirits – - – laquer thinner evaporates too fast
-- "_If we did all the things we are capable of doing, we would literally astonish ourselves_." Edison
View Jack_T's profile
Jack_T
620 posts in 1228 days
#3 posted 777 days ago
I also wipe the project down with mineral spirits. Remember to use a raking light (bright light shining across the project at an angle) at the same time to see defects when you do this.
-- Jack T, John 3:16 "For God so loved the world that he gave his only Son, so that everyone who believes in him might not perish but might have eternal life."
View shipwright's profile
shipwright
3480 posts in 995 days
#4 posted 777 days ago
One thing you can do is mask your glue area and stain first. Or, you just don’t have the problem with hide glue.
-- Paul M ..............If God wanted us to have fiberglass boats he would have given us fiberglass trees. http://prmdesigns.com/
View Steven H's profile
Steven H
1104 posts in 1257 days
#5 posted 777 days ago
Mineral spirits take sooo long to dry, use ACETONE. It also removes glue.
It also is great for checking leftover glues.
-- shdesign3.com
View Bernie's profile
Bernie
396 posts in 1034 days
#6 posted 777 days ago
CR is right… let it dry and then clean it off with a good sharp chisel and or cabinet scraper. But I would like to add an interesting comment. I use a popular market glue and reading the instructions on the back, it tells me to use a wet or damp rag to wipe off the excess glue before it dries. Do not follow their instructions… DO NOT WIPE EXCESS GLUE WITH A DAM RAG! What that does is very bad. This dilutes the glue and allows it to penetrate deeper into the wood. There is nothing wrong using mineral spirits, but I prefer to use water. Whatever you use, be sure to put a light on it and look at with using an angle so you can detect the glue in the shine. My preference for water is that it shows me all the blemishes like mineral spirit, but it also pops out my dents. Don’t drown your work, simply dampen it. Done correctly, you can apply your finish within 20 minutes.
-- Bernie: It never gets hot or cold in New Hampshire, just seasonal!
5028 posts in 1845 days
#7 posted 777 days ago
You can use a black light with some glues. I’ve never tried it.
With furniture I pre-finish.
I’m also very neat with glue. Let it get soft-hard then wick it off
with a pointed stick or a drinking straw cut at a steep angle. The
excess you can scrape off with a razor blade. I do this on guitar
bracing.
Don’t use too much. Don’t try to clean it up with water. Bad.
A pair of angle chisels is very useful for glue squeeze out. Angle
dog-leg chisels are even better.
View papadan's profile
papadan
1076 posts in 1565 days
#8 posted 777 days ago
Dry assemble, tape along all joints, cut tape between pieces and glue up. Peel off tape and all squeeze out. I do this with all glue joints even though I don’t use stains, just clear finishes.
-- Carpenter assembles with hands, Designer builds with brains, Artist creates with heart!
Alongiron
#9 posted 777 days ago
Thanks for all the great tip and tricks! This is what is so great about this site. Not only can I learn from asking a question..we all benefit from it! Thanks again!
View FaTToaD's profile
FaTToaD
237 posts in 1338 days
#10 posted 777 days ago
I second the use of acetone. When I’m having problems getting to the glue with a chisel, I’ll put a little acetone a qtip and rub it over the glue. That usually does the trick. Thought I’ve always been a little concerned about getting acetone into the joint itself and weakening it.
-- David
Steven H
#11 posted 777 days ago
FaTToaD
You do not want to be soaking acetone on the wood or else it will remove the joint glue. Wipe off Acetone immediately after you remove the glue.
-- shdesign3.com
