Jet WBS-14 bandsaw blade adjusting screw frozen
Forum topic by BFamous posted 03-20-2018 01:37 AM 1373 views 0 times favorited 14 replies Add to Favorites Watch
View BFamous's profile
BFamous
226 posts in 358 days
03-20-2018 01:37 AM
All,
I have a JET bandsaw I inherited two years back that I’m starting to get into using, however the blade adjusting screw is completely frozen. I can’t turn it at all.
Before I start taking the entire thing apart to figure out what’s wrong, I figured I’d ask to see if anyone has experienced the same or had advice.
I’m ok with buying replacement parts or upgrades, but wanting to understand my options first.
Thanks
-- Brian Famous :: Charlotte, NC :: http://www.FamousArtisan.com
14 replies so far
View tomd's profile
tomd
2186 posts in 4008 days
#1 posted 03-20-2018 01:50 AM
I’m not sure what you mean by the blade adjusting screw, but if you mean the screw or bolt that controls the tilt of the top wheel to center the blade they usually have a lock nut on them at the base of the screw or bolt.
-- Tom D
BFamous
#2 posted 03-20-2018 02:00 AM
Tom,
Blade adjusting screw is what the manual calls what I refer to as the tensioner rod. What you turn to adjust the tension on the blade.
View TheFridge's profile
TheFridge
10816 posts in 1723 days
#3 posted 03-20-2018 02:04 AM
Won’t go either way? Not even a bit?
Spray with PBBlaster and a couple taps with a hammer is always the first go to. Then heat and PBB and hammer.
If you can get it to move an inch, you can get it to move a mile.
BFamous
#4 posted 03-20-2018 02:15 AM
WD40 is soaking on it right now. Was gonna let it sit overnight, and then try again in the morning.
And no, it was not moving either direction… I had 12” lock jaw pliers on it and wasn’t budging it.
View toolie's profile
toolie
2148 posts in 2866 days
#5 posted 03-20-2018 02:58 AM
And no, it was not moving either direction… I had 12” lock jaw pliers on it and wasn t budging it.
- BFamous
Liquid Wrench? I always have plenty of it on hand when I refurb a machine. Always seems to do the job.
BFamous
#6 posted 03-20-2018 03:03 AM
Well, PBB and a bigger wrench got it moving and now that I have it out, I can definitely see where some of the threads are what I’ll call chilled or bent. Unfortunately, my tap and die set is metric, so I’m not certain if I can re-thread it…
Any suggestions on where to get a new one if I can’t fix this one? Or is there a worthwhile upgrade that would make replacing this one unnecessary?
View Jim Dawson's profile
Jim Dawson
114 posts in 1070 days
#7 posted 03-20-2018 11:14 PM
If the threads just need cleaning up, wouldn’t buying the correct die be the cheapest option?
View MrUnix's profile
MrUnix
7106 posts in 2436 days
#8 posted 03-20-2018 11:16 PM
- Jim Dawson
Or just use a thin needle/thread file and clean them up.
View John Smith's profile (online now)
John Smith
1550 posts in 400 days
#9 posted 03-20-2018 11:23 PM
one tool that I have – that I never need – until I need it – is the Thread Restoring File.
quickly and accurately restores damaged threads. less than $20 new.
also, if you can find a case hardened nut the size you need at BORG may help.
-- I started out with nothing in life ~ and still have most of it left.
BFamous
#10 posted 03-21-2018 12:46 AM
- Jim Dawson
Some of the ridges right in the sweet spot are chipped and bent. I’m not certain if using the correct die would make it strong enough to not slip under high pressure. I’ll probably try that route first, but just wondering if some of the other options out there are worthwhile. I was looking at the Accuright Ratchet Rod for like $45. I could care less about the ratcheting part, but like the fact it has a 3/8 drive on the top instead of threads for a handle (my handle constantly loosens these days because it’s just threaded on). I’ve spent that much money in worse ways in my life, but was also thinking about just buying a 3/8 -16 acme threaded rod for around $15 and coming up with my own handle (maybe grind it square for a 1/4” drive).
Just looking for ideas at this point.
MrUnix
#11 posted 03-21-2018 01:05 AM
Are you sure it’s an SAE thread (3/8-16)? Just about everything on those machines should be metric I would think. I can’t remember any import machine I’ve seen/worked on that doesn’t use metric stuff.
BFamous
#12 posted 03-21-2018 01:16 AM
Are you sure it s an SAE thread (3/8-16)? Just about everything on those machines should be metric I would think. I can t remember any import machine I ve seen/worked on that doesn t use metric stuff.
- MrUnix
I haven’t fully confirmed it yet, but all signs point to it being so. Most significantly none of my metric dies fitting properly even on the clean threads.
Though I also don’t know if it really matters what the current one is, as if I replace the rod I’m 95% assuredly going to replace the nut too. Am I wrong in thinking that I just need to worry about the rod and nut matching? There’s no threads in the slide itself, right?
BFamous
#13 posted 03-21-2018 01:17 AM
Oh, also, I’m at least the third owner of this machine… So there’s no guarantee what is on here is original at this point…
View fivecodys's profile
fivecodys
1271 posts in 1874 days
#14 posted 03-21-2018 08:50 PM
I would just replace that rod and while you are at it, swap the adjustment knob with a crank.
That’s what I did. Works way better now.
Sorry I don’t have a better picture. I just cropped this out of another photo I had.
-- I always knew I would grow old, But I expected it to take longer!
