too much lacquer
Forum topic by walkingscar posted 03-20-2018 12:44 AM 603 views 0 times favorited 11 replies Add to Favorites Watch
View walkingscar's profile
walkingscar
4 posts in 1462 days
03-20-2018 12:44 AM
cheers all,
i build small boxes and my finish of choice is lacquer. however i have to use so many coats to get a good finish because it soaks into the wood. is there any finish i could use under the lacquer to seal the wood resulting in fewer coats of lacquer.
walkingscar
11 replies so far
View AlaskaGuy's profile
AlaskaGuy
4990 posts in 2546 days
#1 posted 03-20-2018 04:06 AM
Are you using rattle can lacquer?
View Rich's profile
Rich
4001 posts in 826 days
#2 posted 03-20-2018 04:30 AM
Like AlaskaGuy suggests, the amount of solids varies in different lacquer products. There are some high solid lacquers sold in aerosol cans too.
View William Shelley's profile
William Shelley
608 posts in 1706 days
#3 posted 03-20-2018 05:35 AM
The “Brushing Lacquer” is a lot thicker, in my experience, and covers better.
-- Woodworking from an engineer's perspective
walkingscar
#4 posted 03-20-2018 07:34 AM
i use spray lacquer but i do have some brush on. i will try that as a first coat and see how it works. where can i get high solid spray lacquer?? thanks for your replies.
walkingscar
View Rich's profile
Rich
#5 posted 03-20-2018 09:48 AM
- walkingscar
http://magicwoodrepair.com/items/aerosol-clear-finishes/pre-catalyzed~clear-/pre-cat-high-solids-satin-35-sh-m102-0335-detail.htm
View OSU55's profile
OSU55
2026 posts in 2227 days
#6 posted 03-20-2018 12:18 PM
Perhaps a blotch control method would work. Read here. Only if you dont color the wood. The glue size or thinned wb finish will raise the grain and require a light sanding. Properly wiped off either will not interfere with the lacquer.
View Jim Finn's profile
Jim Finn
2688 posts in 3159 days
#7 posted 03-20-2018 01:05 PM
I also make many small boxes. Mine are made of cedar, which is a soft wood and absorbs finish a lot. I gave up on using lacquer and now I apply one coat of shellac, I wipe it on. I then sand it smooth with my orbital sander using 180 grit. I then apply two coats of wipe on poly sanding between coats only if necessary. Shellac will also work under lacquer.
-- No PHD just a DD214 Website> craftingcouple.com
View Tony1212's profile
Tony1212
267 posts in 1972 days
#8 posted 03-20-2018 01:34 PM
- Jim Finn
Is that the de-waxed sanding sealer shellac or just regular shellac? I’ve always been afraid of putting anything over the regular shellac since I figure the wax in it would prevent a good bond.
-- Tony, SW Chicago Suburbs
William Shelley
#9 posted 03-20-2018 01:50 PM
- Jim Finn
Is that the de-waxed sanding sealer shellac or just regular shellac? I ve always been afraid of putting anything over the regular shellac since I figure the wax in it would prevent a good bond.
- Tony1212
You are correct, the wax will cause problems for some finishes. But de-waxed shellac is fine. It’s sold by Zinsser as “SealCoat” in a pre-mixed variety.
Jim Finn
#10 posted 03-20-2018 03:51 PM
I just used “Bullseye” clear shellac from Lowes.
View jdthomas's profile
jdthomas
4 posts in 308 days
#11 posted 03-20-2018 05:06 PM
Sealing with regular shellac (with wax) will be okay if you are following with oil-based. The SealCoat, which as William Shelley pointed out, is de-waxed, would be good under either oil- or water-based. I’ve used the SealCoat several times. It’s a 2 lb. cut and it’s a little sticky, so I’ve thinned it 50/50 with denatured alcohol and wiped on several coats. It’ll raise the grain a bit, so may want to give a light sanding before continuing on with your lacquer.
