Large Nails for dolly axles
Forum topic by Elder posted 05-03-2011 04:51 PM 1112 views 0 times favorited 2 replies Add to Favorites Watch
View Elder's profile
Elder
8 posts in 2783 days
05-03-2011 04:51 PM
Topic tags/keywords: question dolly axle
I am building a Air Compressor cart and am at the part of the project where I need to attach the casters and 2 larger wheels in the back of the dolly. I am going to use 2 60D nails as the axle for my wheels and was wondering if anyone has done this before. I was going to simply drill the holes and attach the wheels with a washer and then slide the nail in place. Suggestions???
Thanks,
Matt
2 replies so far
View HerbC's profile
HerbC
1790 posts in 3062 days
#1 posted 05-03-2011 05:29 PM
Matt,
1. Drill the hole in the cart frame slightly smaller than the diameter of the nail.
2. Consider drilling a hole through the frame and nail for a small bolt to be used as a retainer.
3. Use four washers per wheel. Two large metal fender washers and two nylon washers in direct contact with the wheel.
Good Luck!
Be Careful!
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
Elder
#2 posted 05-03-2011 05:33 PM
Thank you for the advice I will do just that!
