Craftsman 10" Contractor Table Saw
Forum topic by vwmike99 posted 55 days ago 222 views 0 times favorited 6 replies Add to Favorites
View vwmike99's profile
vwmike99
5 posts in 55 days
55 days ago
Topic tags/keywords: tablesaw question trick tip
I have a Craftsman 10” contractor saw that really sucks. Doesn’t have enough work surface, or an efficient rip fence. The blade tilts to approx. 42 degrees, so cutting a 45 is nonexistent. Can anyone share how to jazz up this saw so I don’t throw it out into the street, or should I just bite the bullet and save for a Delta Hybrid?
-- California scares me - so I'll just stay in the garage and build something!
View Phred's profile
Phred
3 posts in 55 days
55 days ago
Hey vwmike99..
I have a 10” Craftsman Contractors saw.. I bought a new fence for it, I was able to get a 30” Delta fence from a local dealer for about $200 Canadian.. (Probably cheaper in the US) much better.. pretty much the same fence that comes with the delta hybrid. took a bit to get installed, but worth the investment. Also, You should be able to adjust the 45 degree (or 42 in your case) by adjusting one of the stops on the inside. You can order a replacement manual from Sears for your saw too.. most of the parts should be available for it too..
-- If only there was a way to combine Computers, Hockey and Woodworking.........
vwmike99
5 posts in 55 days
55 days ago
Thanks Phred – I’ve been thinking about building a new fence system and work bench around the saw, but I think if I do it the way I’d like to, I’d invest half a new Hybrid saw (lol). I just found out on another site that there is an adjustment for the 45 stop. I’ll have to flip the saw over when I get a moment or two. Fact remains, I really want a Delta Hybrid Saw. :))
Phred
3 posts in 55 days
55 days ago
I was thinking of the hybrid saw too.. but I think I’m going to hold out for a 3HP sawstop. My boss bought one, and I think it’s worth the wait.
Just a tip.. if you decide to give yours a tuneup, don’t be afraid to create a wood base for it, I did for mine, really helped to firm the whole thing up, and almost kill all the vibration. I built mine similar to this one:
http://www.binkyswoodworking.com/TblSawCab.html
vwmike99
5 posts in 55 days
55 days ago
Thanks for that link Phred! That’s something that I might SERIOUSLY consider doing. Should hold me over until a Hybrid Saw is parked in my garage!
View Scott Bryan's profile (online now)
6462 posts in 156 days
55 days ago
VWMIKE,
There are several posts on installing the Delta T2 fence posted here. Just use the search routine to find them. That should help with the fence problem. I feel your pain. The fence on mine is awful. You should be able to access the 45 stop from the top of your saw with an allen wrench. But before adjusting it make sure that sawdust or other debris isn’t interfering with your bevel operation.
But then again you may just want forget about all this and go ahead with the new table saw.
View ww_kayak's profile
ww_kayak
61 posts in 59 days
54 days ago
As far as work surface goes I added an outfeed table and extended the table. The cheapo Craftsman fence system on mine is just 1” angle iron so I replace with longer pieces and added a melamine surface between. It’s still a craftsman, and the fence still sucks, but with the right jigs, sleds, techniques, it’s WAAAAY better than it was :) Oh and the extra legs for the outfeed and extension stabilized the saws crappy sheet metal legs.
Table Saw
-- Tom, Central New York
