gear box oil for Jet JWP-15CS Planer
Forum topic by need2boat posted 05-03-2011 01:45 AM 4658 views 0 times favorited 4 replies Add to Favorites Watch
View need2boat's profile
need2boat
544 posts in 2564 days
05-03-2011 01:45 AM
Topic tags/keywords: jet planer gear oil
I got a new to me 9/10 year old jet 15” planer that I’m guessing has never had the gear oil changed. The previous owner really didn’t use it much and reading the manual it says to change the gear every year and it’s calling for 50w gear oil.
I’ve looked quite a bit in my area but just can’t seem to find 50w anywhere. Just wondering what others are using. 75w is the standard in most auto stores.
thanks
Joe
-- Second Chance Saw Works http://www.secondchancesawworks.com Blog: Positive Rake http://www.positiverake.com
View crank49's profile
crank49
4028 posts in 2842 days
#1 posted 05-03-2011 04:38 AM
If it calls for 50w you better not substitute. I haven’t seen the machine you speak of, but the reason for using a lighter weight oil is to reduce heat buildup when running at high speeds.
View Pete_Jud's profile
Pete_Jud
424 posts in 3624 days
#2 posted 05-03-2011 05:14 AM
When I bought my JWP-15 a few years ago, I changed the oil, and cleaned everything, It had been used hard before me, I can’t seem to find the manual right now, but I don’t think that there was anything special about the oil, I keep 30, 40, and 80/90 wt around here for the cars, trucks, and tractor. And I can’t recall having to make a trip to the store to pickup oil.
-- Life is to short to own an ugly boat.
need2boat
#3 posted 05-04-2011 01:45 PM
A few friends pointed out that getting 50w motor oil is easy to come by so I did a little looking around and found gear oil and motor oil are not on the same scale. I’m going to contact Jet tech department and see what they have to say. I have a feeling 70-90 will be better then switching over to wither air gun oil, also 50 weight or motor oil.
need2boat
#4 posted 05-23-2011 07:12 PM
Just as an update for future people I spoke with the tech department at Jet. They said 85/90 regular truck gear oil would work fine.
