I'm Screwed
Forum topic by doninvegas posted 752 days ago 1163 views 0 times favorited 19 replies Add to Favorites Watch
View doninvegas's profile
doninvegas
311 posts in 1078 days
752 days ago
I have been searching the net for a couple of day now but can’t seem to find #3 X 5/8 steel wood screws. I can find brass but I need steel. Does anyone know of a source?
-- "Courage is being scared to death -- but saddling up anyway."
19 replies so far
87305 posts in 1748 days
#1 posted 752 days ago
Have you looked here?
http://www.fastenal.com/web/products.ex
or here
http://www.louisandcompany.com/
View papadan's profile
papadan
1076 posts in 1539 days
#2 posted 752 days ago
Most of whats advertised as brass is just plated.
-- Carpenter assembles with hands, Designer builds with brains, Artist creates with heart!
View sandhill's profile
sandhill
1978 posts in 2095 days
#3 posted 752 days ago
I had the same problem and ended up with stainless steel.
doninvegas
#4 posted 752 days ago
OK, here’s the thing. I’m making lazy susan’s and when I need to fasten the base with bearing I drill a hole in the base and have to screw the base to the main (top) LS. It’s really a pain with brass screws. If I could get steel I could use a magnetic screw drive to install the screws.
Jim, Fastenall doesn’t sell these small screws and the other link I get an error when I click on fasteners.
Sandhill, where did you get the SS screws?
#5 posted 752 days ago
How about 1/2” screws the should hold well? I forgot you have to have an account with Lewis and company(wholesale)
View John Ormsby's profile
John Ormsby
1238 posts in 1908 days
#6 posted 752 days ago
Don,
Here is a link to a place that has your screws.
http://www.boltdepot.com/product.aspx?cc=3&cs=31&cm=7&cd=524
-- Oldworld, Fair Oaks, Ca
doninvegas
#7 posted 752 days ago
Thanks, Ben. I’ll give them a call. I’ll also check out WE. Haven’t been there since they closed the Gibson store.
OK, since I got a local on this thread I’m going to change the subject. Do you know of anyone in town that mills lumber? I have some 4×4 broad leaf maple I need to flatten. It’s 12 to 14 ” wide and I only have a 6” jointer. I need to flatten at least one face and one edge.
doninvegas
#8 posted 752 days ago
Thanks, John. I was hoping to get phillips head screws but it I have to use slotted then so be it.
View D_Allen's profile
D_Allen
495 posts in 955 days
#9 posted 752 days ago
90006A098, Mcmaster Carr
-- Website is finally up and running....www.woodandwrite.com
View Minorhero's profile
Minorhero
103 posts in 776 days
#10 posted 752 days ago
D_Allen beat me to it. McMcaster has them for about 4.35 for a pack of 100. Shipping will end up being around another 4 dollars.
View crank49's profile
crank49
2290 posts in 1142 days
#11 posted 752 days ago
http://www.mcmaster.com/#pull-out-resistant-wood-screws/=c4y7qb
Here’s the link for McMasters Carr.
If these guys don’t have it, you probably didn’t need it.
-- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason.
View derosa's profile
derosa
1472 posts in 1007 days
#12 posted 752 days ago
Just remember that true stainless isn’t magnetic and won’t work with your magnetic screw driver any better then the brass.
-- --Rev. Russ in NY-- A posse ad esse
View Harry_Ch's profile
Harry_Ch
54 posts in 847 days
#13 posted 752 days ago
Have you trried looking at Bolts Depot? They have a large selection of wood screw at good
http://www.boltdepot.com/Default.aspx
-- Deeds not Words.
View jaw's profile
jaw
2 posts in 964 days
#14 posted 752 days ago
McFeeley’s has a good assortment in both plain and plated steel, but they start at #4.
doninvegas
#15 posted 751 days ago
I just bought them from McMaster-Carr. Really wanted the phillips head but you get what you can.
