Unisaw V belt size
Forum topic by hkmiller posted 03-19-2018 03:56 PM 657 views 0 times favorited 9 replies Add to Favorites Watch
View hkmiller's profile
hkmiller
114 posts in 317 days
03-19-2018 03:56 PM
I just got an old unisaw it’s a 34 450 and I want to replace the V belts are they standard sizes you can get it automotive store is it a special size it has three belts
-- always something
9 replies so far
View Woodknack's profile
Woodknack
12455 posts in 2615 days
#1 posted 03-19-2018 04:58 PM
Not every autoparts store carries machine belts. Napa does. Just take the belts in and they will match them up.
hkmiller
#2 posted 03-19-2018 05:02 PM
- Woodknack
sounds good. Thanks!
-- always something
MrUnix
7106 posts in 2434 days
#3 posted 03-19-2018 05:18 PM
From the Vintagemachinery Wiki: Unisaw Replacement Belts
View jonah's profile
jonah
1971 posts in 3534 days
#4 posted 03-20-2018 01:27 AM
Any Grainger store will have the right size belts. Just bring one in and they’ll match it.
View coxhaus's profile
coxhaus
93 posts in 1130 days
#5 posted 03-27-2018 08:41 AM
I used the Gates premium AX belts on my Unisaw. They worked great. I bought them at Oreilly’s auto parts store.
hkmiller
#6 posted 03-27-2018 12:14 PM
I used the Gates premium AX belts on my Unisaw. They worked great. I bought them at Oreilly s auto parts store.
- coxhaus
What size belt did you get the length I’m thinking is probably around 24 in
-- always something
coxhaus
#7 posted 03-28-2018 04:34 AM
I think that is right. It was over a year ago. The Gates Premium AX belts are so good they do not need to be matched. They already are. You have to size the belts to the pulley size. I have a 3HP Baldor 3400 motor.
I found this on another site for a 3450rpm motor you need ax24/4L260 belts. Ax27/4L290 for a 1725rpm motor.
MrUnix
#8 posted 03-28-2018 05:29 AM
The link I gave above to the VM Wiki lists the belts sizes used through the years – they were different depending on what motor and arbor pulley size you have. Generally, for anything after the 50’s (unless modified by a PO at some point) standard A24 (AX24, 4L260, etc…) belts can be used.
hkmiller
#9 posted 03-28-2018 10:59 AM
Thanks guys. I will go with the ax24/4l260
-- always something
