Attaching solid wood boards to a plywood dresser top?
« back to Joinery forum
Forum topic by Smithwhit posted 03-19-2018 03:10 PM 1162 views 0 times favorited 8 replies Add to Favorites Watch
View Smithwhit's profile
Smithwhit
5 posts in 304 days
03-19-2018 03:10 PM
Hello -
Looking for a bit of guidance (novice here). Recently built a dresser out of clear pine/plywood, but would love to add a pine top to the plywood with a small overhang to give the dresser a more finished look. I was thinking of either using pocket holes or gluing the 1×4s together, but – how should I attach it to the plywood to allow for movement? I was thinking figure 8 fasteners? Probably should have planned ahead a bit more but this is where I am! Any suggestions would help! I’ve attached a picture of where I am so far!
8 replies so far
View BFamous's profile
BFamous
221 posts in 356 days
#1 posted 03-19-2018 03:22 PM
Make short slots in the plywood, going in the same direction as the grain of the hard wood top, and then use bolts/screws up through the plywood top, through those slots and into the hard wood. The slots will allow the fasteners to slide with any movement of the hard wood top.
-- Brian Famous :: Charlotte, NC :: http://www.FamousArtisan.com
View Rich's profile
Rich
3991 posts in 825 days
#2 posted 03-19-2018 03:52 PM
- BFamous
Not in the same direction as the grain. The top won’t move along the grain, but tangentially, across it. The slotted holes need to run across the grain of the top, likely front to back, to allow the wood to move.
If you have enough of an overhang to conceal it, then the figure 8s you mentioned would work, as would Z-clips.
BFamous
#3 posted 03-19-2018 04:08 PM
- BFamous
Not in the same direction as the grain. The top won t move along the grain, but tangentially, across it. The slotted holes need to run across the grain of the top, likely front to back, to allow the wood to move.
- Rich
Rich,
So are so correct. Ugh. I shouldn’t try to answer questions while I’m at work and only half paying attention… I’m editing my original reply…
View dday's profile
dday
168 posts in 1665 days
#4 posted 03-19-2018 04:35 PM
Why not finish it with another piece of that beautiful, clear pine plywood?
Do the overhang to give it some depth and then frame the plywood ends with some solid wood trim.
That way, you won’t have to account for movement and the grain and color will match throughout
Smithwhit
5 posts in 304 days
#5 posted 03-19-2018 06:04 PM
Thank you for the quick input! As mentioned, total beginner/YouTube learner here (obviously) and appreciate the help and advice! Nice being able speak with people who know their stuff. Now just have to finish this up before baby comes! It’s a bit harder to move around my shop (aka basement aka laundry room aka nothing fancy) being 30 weeks pregnant! :)
View Rich's profile
Rich
#6 posted 03-19-2018 08:31 PM
To amend my earlier post, you only need to make one set of holes slotted. If you go with screws from underneath, you can screw the front down, and only the rear needs to allow movement. It’s common when pinning but allowing for movement like that to pin it at the front, so the front lines remain clean and even and let the movement happen in the rear. (Make that at the rear — it sounds nicer).
View bilyo's profile
bilyo
472 posts in 1338 days
#7 posted 03-19-2018 10:28 PM
To elaborate a little on what has been said above if I may: As has been mentioned, the object of the oblong holes and screws, of course, is so the screws can slide in the oblong hole as the wood top is either expanding or contracting. The type of screws you use matters. You don’t want a flat head screw made for counter sinking as it will embed itself into the hole and not slide. Even a round head screw head might be too small and also not slide properly. If that is all you have, be sure to use a flat washer under the head. I have found that washer head screws work for this purpose very nicely. Don’t over tighten.
One final point. Be sure to use plenty of screws to hold the top. Remember that it is common for one to use the top overhang as a finger hold when moving the chest. Particularly with soft wood like pine, it will be relatively easy to pull the screws out when doing this if there are not enough.
Nice looking chest. Good work.
Smithwhit
5 posts in 304 days
#8 posted 03-19-2018 11:25 PM
Awesome! Thank you so much!!
