HELP!: Tried to remove the impeller from HF Dust Collector w/ Gear Puller...
Forum topic by WorksInTheory posted 03-18-2018 11:06 PM 1299 views 0 times favorited 12 replies Add to Favorites Watch
View WorksInTheory's profile
WorksInTheory
137 posts in 1565 days
03-18-2018 11:06 PM
... and the lip of the hub broke off. I rotated the gear puller slightly to regrab what was left of the lip and it broke off more parts. Looks like the hub is stuck and now I don’t have any lip to line up w/ the gear puller arms (3 arm puller).
Any other ideas to pulling this thing off. I am at point of no return so need to get it off and put the new bigger one in.
Thanks for any advice and ideas.
12 replies so far
View GR8HUNTER's profile
GR8HUNTER
3628 posts in 675 days
#1 posted 03-18-2018 11:30 PM
PICTURES may help :<))
-- Tony Reinholds,Pa. REMEMBER TO ALWAYS HAVE FUN
WorksInTheory
#2 posted 03-18-2018 11:34 PM
You can see the lip broken in a few places. I am thinking at this point need to just crack the hub and dump this impeller, esp since I have a new one. Don’t know how else to grab on and have leverage to get it off.
View WhyMe's profile
WhyMe
1007 posts in 1523 days
#3 posted 03-19-2018 12:46 AM
With some tension on the puller did you hit the bolt end with a hammer before trying to just cranking on the bolt to remove?
WorksInTheory
#4 posted 03-19-2018 01:00 AM
I didn’t and know now I should have been now trying it with the bigger gear puller pulling on the outer disk and doing it – it’s not budging. I don’t know if it’s rusted in or something.
I am about to put a grinder to it to cut it out… frustrating.
View Jbay's profile (online now)
Jbay
2223 posts in 861 days
#5 posted 03-19-2018 01:09 AM
You do know they just unscrew right?
lol, j/k
I had an old DC that I tried to get the impeller off. Tried everything from heat to a bigger hammer. Never got it off. Chucked the whole damn thing. Was going to anyway.
View Rayne's profile
Rayne
827 posts in 1502 days
#6 posted 03-19-2018 01:55 AM
Crazy thought, whack it with a hammer to jar it kind of loose, then maybe use multiple snap rings of that size to create an edge for the gear puller to work. Just thinking of possibilities of what I would try if I had that problem.
WorksInTheory
#7 posted 03-19-2018 05:32 AM
Thanks all – I tried a bunch of things… that were destructive probably half from frustration and playing on tilt. But eventually I got it off by drilling a bunch of holes to create larger holes to fit the gear puller hooks into. Then it still took a humongous amount of torque-ing until finally getting it off.
View Sparks500's profile
Sparks500
152 posts in 293 days
#8 posted 03-19-2018 12:13 PM
Heat is your friend…
-- A good day is any day that you're alive....
View TheFridge's profile
TheFridge
9249 posts in 1448 days
#9 posted 03-19-2018 12:30 PM
Either split it by cutting most of the way through with a sawzall and cold chiseling it. Or drilling and tapping holes in the hub and putting a different puller on.
Personally, I’d split it and be done.
View bonesbr549's profile
bonesbr549
1531 posts in 3029 days
#10 posted 03-19-2018 12:37 PM
- Sparks500
I was thinking the same thing…..
View Kelly's profile
Kelly
1994 posts in 2906 days
#11 posted 03-19-2018 03:57 PM
Then there is always the “grind a slot or two in it” trick. I’ve had a few things over the year that I had to grind deep grooves in to get them off. Bearings, immediately, come to mind.
You could use an angle grinder to get most of it down, then switch to the exploding Dremel type wheels.
If you can work over the keyway, if there is one, you get a bit more leeway. If you can get it down to, say, 1/16th, a sharp cold chisel toward the motor and bearing (so you don’t risk bending a shaft, might spread it enough to pull off.
View skipj's profile
skipj
97 posts in 2235 days
#12 posted 03-20-2018 01:16 PM
Just for information. When you put the new impeller on and you screwed up the threads on
the the shaft with the puller you are going to need a 6mm left hand tap.Don’t ask how I know this.
