Polishing/treating brass and copper
Forum topic by Clarence posted 752 days ago 2084 views 0 times favorited 12 replies Add to Favorites Watch
View Clarence's profile
Clarence
125 posts in 1276 days
752 days ago
I have several projects on the drawing board that include the use of brass and/or copper. For instance, I have a large number of 1920s vintage glass door knobs with brass bases , as well as their brass escutcheons, that I intend to turn into coat racks by mounting them on oak boards.
My question: how do I remove all tarnish or oxidation from the brass (and copper) and how do I treat it to keep it off without having to go back periodically and polish it?
-- Getting old is a good thing, but being old kinda stinks.
12 replies so far
View ChefHDAN's profile
ChefHDAN
141 posts in 1019 days
#1 posted 751 days ago
I collect copper fire extinguishers and some of them don’t have any patina on them per se so I keep them bright polished. There are many commercial polishes that will do a good job but it can be exhausting if it’s a big piece. Since you’re dealing with smaller pieces, you might try a buffing wheel in the drill press to work the polish. After polish you can spray a lacquer coat to seal the part and prevent return of the oxidation tarnish
View DaleM's profile
DaleM
800 posts in 1554 days
#2 posted 751 days ago
I use Brasso metal polish. I’ve used it to polish my brass when I was in the Army and use it now to polish up my old sink fixtures, an old light switch cover, and quite a few other things around the house. If you spray clear poly over the brass after polishing, it will preserve the shine and keep it from oxidizing.
-- Dale Manning, Carthage, NY
View Dan's profile
Dan
3480 posts in 1050 days
#3 posted 751 days ago
Another option to make it go even faster is to sand the brass with a really fine grit paper. You can sand brass rather well without damaging it. I usually sand tarnished brass with 800 grit paper then 1000 and after that I will use the brass polish. After its polished you can sand again with a 2000 grit paper for a super shiny finish.
-- Dan - "Collector of Hand Planes"
View paratrooper34's profile
paratrooper34
699 posts in 1122 days
#4 posted 751 days ago
Brasso would be good to get the brass and copper bright again. However, with those old doorknobs, they usually have a lot of decoration which means lots of recesses and such. Although I haven’t done one of those specifically, I had the same issue with other items. I used Brasso to remove most of the patina. To get in all the crevices and such, use a Dremel tool with a felt tip polisher bit. Dip it in the Brasso and work it in to those small areas. Be dilligent and it will work. Make sure you wear eye-pro, Brasso hurts in the eye (ask me how I know!).
-- Mike
87200 posts in 1747 days
#5 posted 751 days ago
Brasso or rubbing compound for automotive work they also sell little buffing pads that fit on the end of your drill that you can put the rubbing compound on. after their clean some clear lacquer will keep it shinny until it wares off.
View mrg's profile
mrg
483 posts in 1169 days
#6 posted 751 days ago
Ketchup or vinager will clean them up.
-- mrg
View peteg's profile
peteg
2278 posts in 993 days
#7 posted 751 days ago
After polishing them up you can use a good wax polish (furnituer polish will do fine,) all you are realy trying to do is seal the surface to stop exidation
View Chelios's profile
Chelios
567 posts in 1236 days
#8 posted 751 days ago
DaleM
#9 posted 751 days ago
After looking at Dan’s blog that Chelios just linked and the metal polish that he used, I see now why Dan said above to use 2000 grit sandpaper after the metal polish. With Brasso, that would not be necessary because unlike those other polishes, it has a suspended silica abrasive. Using 2000 grit sandpaper would actually be a step back because the Brasso is actually way finer than that, somewhere around 12,000 grit I believe. I know it is way finer than jeweler’s rouge and finer than 8000 grit micro-mesh just by the difference in the surface it leaves.
View auggy53's profile
auggy53
160 posts in 850 days
#10 posted 751 days ago
i tryed ketchup to clean a copper pot rack a few years ago and the ketchup stained it so bad i had to toss it . i tried everything i could find to get it off but nothing worked . the closest i got to cleaning it was some stuff called wizard used in auto body shops.
-- rick
View racerglen's profile
racerglen
1695 posts in 950 days
#11 posted 751 days ago
Autosol , available at automotive supply shops (and Lee Valley) Works very well.. for the fine decoration, the recesses etc, a soft toothbrush with whichever cleaner/polish you choose, will
work very well.
-- Glen, Vernon B.C. Canada
View Bertha's profile
Bertha
13111 posts in 863 days
#12 posted 750 days ago
I like brasso and a cheap $10.00 WalMart automotive buffing pad. We used to polish brewery brewkettles in this way. I don’t miss that job. :)
