Jointer Question
Forum topic by prap posted 05-02-2011 03:38 AM 2023 views 0 times favorited 4 replies Add to Favorites Watch
View prap's profile
prap
50 posts in 2912 days
05-02-2011 03:38 AM
What’s the difference between the Grizzly GO604 and the GO604X jointer?
View mfike's profile
mfike
100 posts in 3903 days
#1 posted 05-02-2011 06:09 AM
The go604x is a parallelogram jointer, which has adjustments to keep the in and outfeed table parallel to each other. The go604zx is identical, but with a spiral cutter head. The go604 does not have the built in adjustments to keep the infeed and outfeed tables parallel. You would have to shim it if it were not parallel.
View prap's profile
prap
#2 posted 05-03-2011 01:50 PM
Sorry, I’m a little confused. I don’t know much about jointers but I thought the out feed table was supposed to be higher than the in feed table? I seen one on c/l, A Grizzly GO604 for $300, I went on the Grizzly site and the only difference I could see was that 604 was a 1 hp and the 604Z was a 1.5 hp. Is this a good deal?
View Bertha's profile
Bertha
13551 posts in 2930 days
#3 posted 05-03-2011 02:08 PM
It sounds like a good deal to me.
View TheWoodNerd's profile
TheWoodNerd
291 posts in 3428 days
#4 posted 05-04-2011 10:35 PM
Parallel and co-planar are two different things. Yes, the outfeed table is higher, but should be absolutely parallel to the infeed.
-- The Wood Nerd -- http://www.thewoodnerd.com
